Drag Radial Guys....what pressure you running??
2003 E55 & 2014 GL550
Street that is.....just checked my TPMS....YIKES...they pumped them to 43psi...
Anyway, it keeps asking me to reactivate on dash. I searched the forum and people say to hit the reset button and select reactivate....what the heck am I missing....is that the setting where you "hold for 3 seconds to reset settings"
Thanks for the help
Thanks for the help
C32AMG
Originally Posted by dgussin1
on the street, run 26-29psi. At the track, 14-17 psi.
The lowest I've gone so far with the Nittos is 18 psi.My only street use of these tires is to & from the dragstrip.
Thanks guys....to Griffin.. I got rid of the nag.
Just go to the part of your display where it shows the pressure in all 4 tires and hit the reset button (the button to shut up the beep from hell)...it should ask if you want to check the pressure and it stopped the nag for me. I did this after I did the 3 sec reset to factory defaults. Sorry if this is basic info and you knew this already....I am the idiot who was clueless....just wanted to share in case you didn't
All the best.
All the best.
2005 E55
Thanks for the help
Thanks for the help
Originally Posted by Steve Clark
What make of drag radial are you using?.
2006 CL65
Thanks for the help
Thanks for the help
