Anyone have their chain tensioners replaced per TSB?
Received 1,884 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
LI05.1o-P-056435 JUL13 – 276, 278 and 157 engines rattling noise after start for several seconds, install check valves/replace left & right secondary chain tensioners.
I'm curious how long the noise should be for it to be abnormal. My car was built in Oct 2013. On a cold start, I hear some extra noises (?maybe metallic rattle) but goes away after about 3-5 seconds and then next warm startup maybe a second of it, if at all. Already did a search on the board and only two links to something similar, Dflamer had his fixed at about 1000 or 2000 miles.
Likely will ask tech at oil change time if abnormal, seeing what your thoughts were. Only thing on youtube is this (not same engine, but part of TSB):
2012 C63 P31, 2013 E63 P30
Im going to chime in since I was referenced in the post.
Now that my car has about 18K on it, I am convinced that the noise is back, at least some of the time. There is a metallic rattle for a few seconds on some starts. I have not had the time to completely research it, but it really does sound like the way it did when the car is new.
Except for the fact that it sounds terrible, I am not going to mess with it any further. The dealer did what they felt they had to do. It's a leased vehicle that I will not keep. I was told by the shop foreman that the noise is cosmetic and will not create a major problem. If it does, it will be their problem.
It's important to note that the M157 is not a "sweet" sounding engine, mechanically. It's not ultra smooth, nor quiet, nor sophisticated sounding. Because of this, who knows what other noises are being created by incorrectly functioning components. I'll never know.
Although I did have my creaky pano roof fixed satisfactorily by the dealer, I am not super impressed by my E. I don't dislike it, but I am not in "like" with it as much as I should be. Too many little things.
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
I had them replaced in my CLS. It helped some, but the engine is still noisy on start up. I was told part of the noise is from the high pressure fuel pump.
I had the TSB done a few months ago (on a 2012 E63 wagon). Mine was making what I'd describe as a clattering sound on start-up, maybe just a second or two - but a noise that you'd definitely notice (and might think something was wrong with the car). I mentioned it when the car was in for service and they did the TSB. The clattering sound is completely gone now.
My E90 M3 makes a similar noise after its been sitting around a while - I've mentioned it to the BMW techs - they say its normal - and BMW does not have a similar TSB fix.
