e63 2014 vibration
E63 AMG - S 4Matic 2014
e63 2014 vibration
Hello,
I drived the car with C mode and high acceleration which leaded to big vibration and i cant drive more than 80 km/h due to vibration. Is this caused to miss-firing plugs?
Received 2,144 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Is it vibrating in the steering
Is it vibrating in the floor of the car?
Does it vibrate under mild acceleration or under acceleration in s or s+
Does it vibrate at idle
Does it vibrate while cruising
I'm tired if typing, your post is too vague, sorry
It could be a thousand things
I sense a small language barrier here. Trying to read into what is asked I do see one clue:
Over 80 km/hour
Sounds like it might just be a wheel balance issue.
But I am guessing without more info as Peter suggested.
When I had vibration issues with mine, they initially said it was slightly bent wheels, but eventually after straightening the wheels and vibration continuing it was resolved by all new rotors and brakes on the car. I will note that I also had the same issue on my GL550 and the cure was complete rotor and brake replacements all covered by MB. The Service Advisor did mention that they have had a whole raft of these replacements.
