Question on noises
Question on noises
When I drive over bumps/rough roads I can hear some metallic noises from the underside of the car. Normal?
Moreso than with any other car I've owned.
Received 1,886 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Not normal as I'm very sensitive to sounds and I'm not hearing that.
Sounds like suspension or something loose in the undercarriage or exhaust system or metal heat shields?
Try and find a speed bump and drive over it a little off the side so only one side of the cars wheels go over. That will hopefully tell you if its the right side or left side. then pay attention if its front or rear.
If it still happens on either side then its not the suspension bits but rather something like the exhaust mounts
