Weird clicking noise while turning right
Old 05-26-2016, 09:59 PM
izzy63's Avatar
2013 C63
Recently picked up a E63S, and didn't notice it the first few days and all of a sudden while I was parking one day I heard the weird clicking noise as shown in the video, took it to the dealer they couldn't figure it out and after I took it back from the dealer even while cruising the noise is apparent as well. It use to be only when I was turning right, anyone have any insights on what could be causing this? Tech at the dealer said the ball joints, control arms and suspension all checked out ok.
Old 05-26-2016, 10:58 PM
EddieK's Avatar
2014 E63S Steel Grey/Beige Nappa, Lexus GX470, Honda Accord
I have no clue what the sound is, but I would have left it at the dealership until they figured it out.
Old 05-26-2016, 11:37 PM
PeterUbers's Avatar
Received 1,881 Likes on 1,319 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Somebody with an e350 had similar sound was the front differential where the axle connects
Another with an e63S had gravel in the axles and this was clear out and resolved
Is this a new car?
Old 05-27-2016, 01:30 AM
izzy63's Avatar
2013 C63
Is this a new car?
It might be the front axle differential the car pulls to the right under hard acceleration and yes it's a new car, I'm taking it back to the dealer in the next couple of days
Old 05-27-2016, 01:31 AM
izzy63's Avatar
2013 C63
It sounds like it's coming from the brakes, but with these cars you never know...
Old 05-27-2016, 01:00 PM
Georgee6086's Avatar
1994 E500, 2012 e63
I have experienced the same noise. But it seems to only happen when im backing out of my girlfriends driveway and I have the steering wheel locked clockwise. It does not happen anywhere else! I have also had the suspension looked at and everything was good. I was thinking in my case that it may be a result of having the wrong tire size on the front which came with the car 255/30/19. I should have my new wheels and tires installed by next week I will report back if the noise goes away.
Old 05-27-2016, 01:22 PM
dav461's Avatar
GTR
CCB?
If yes, it's normal.
Old 05-27-2016, 01:23 PM
PeterUbers's Avatar
Tell those smart techs not to deliver a car back to a customer without a fix. If they can't figure it out they call for help from regional tech
Old 05-27-2016, 01:27 PM
1994 E500, 2012 e63
Originally Posted by dav461
CCB?
No CCB. I wish
Old 05-27-2016, 02:52 PM
izzy63's Avatar
2013 C63
Yup, already called the dealer, set up an appointment for next Tuesday.
Will keep u guys updated if they find anything
Old 06-08-2016, 07:00 PM
izzy63's Avatar
2013 C63
apparently the dealer said the front axles needed to be lubed and the noise is apparently gone, dealer hasn't released the car yet will update again once I pick it up tomorrow
Old 06-09-2016, 09:38 AM
screw991le's Avatar
2010 E63 AMG
Hmmmm, I get the same noise turning left, just recently. I thought it might be the steering rack. But some lube sounds a lot cheaper and easier.
Old 06-12-2016, 03:16 PM
wolves.creed's Avatar
E63s
have the same thing with my car
Old 06-13-2016, 12:27 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
clicking is usually CV Axles are dry or bad, put some grease in the boots and see if it goes away
arcticfox (10-20-2017)
Old 07-12-2016, 03:25 AM
izzy63's Avatar
2013 C63
Just got my car back from the dealership after a third visit, noise is still there they lubricated the front axle noise seems to be a bit better but not by much. Dealership said at this point they can only deem it "normal" thats a load of **** to me. Anyone here manage to fix their clicking noise?
Old 02-01-2017, 11:08 PM
roger1012's Avatar
cls63
Hi OP, is your problem resolved? My 2016 cls63 start to make this noise recently. It sounds exactly the same from your video, I sent the car to the service 2 times already. First time they told me they couldn't replicate the noise, the second time they told me they did a lubrication and apparently the noise is gone. However after I got my car back the noise is still there! At this point they basically told me it seems normal, because they checked every part of the suspension and all seem fine....
Old 02-02-2017, 12:22 AM
izzy63's Avatar
2013 C63
Nope still not resolved I went three times already, they did replace the front axle under warranty but the noise was still there lol they said it wasn't a safety concern and that it was just a "noise" I went to Benzworks and another shop they both said the suspension, control arms, etc all checks out fine
Old 10-16-2017, 03:07 PM
NotABaller's Avatar
2012 C63, 2014 E550
Any update to this?
Old 10-16-2017, 04:20 PM
Anotherone's Avatar
c292 gle63S, Range Rover LWB
It's the wheel bearings. My old X5M had wheel bearing clicking so I know the sound real well. My car does it too, I have an appointment to get it looked at tomorrow.
Old 10-19-2017, 06:44 AM
roger1012's Avatar
cls63
https://www.youtube.com/watch?v=lDypiT4zGAA
Thanks for the info. But mine was not the wheel bearing. At first I thought the wheel bearing was the culprit too(sound similar to your video), however my dealership told me they did inspect all the wheel bearings and found no problem at all. And since the car was still relatively new I highly doubt the wheel bearing would fail this early too...
serveal months have past now and I just learn to accept the fact that this car makes weird noise here and there...
Old 10-20-2017, 07:12 PM
izzy63's Avatar
2013 C63
Yup just get downpipes and the noise will be gone
Quick Reply: Weird clicking noise while turning right
