W212 e63 lowering
Old 09-23-2016, 09:28 AM
chris.bachman's Avatar
a car.
Here are come pictures with stock 19's and aftermarket 20's on my car. The KW front springs have about 3/4" of thread left to lower it more if I wanted.
Old 09-23-2016, 07:14 PM
Ralcbah's Avatar
2018 E63S
Looks great! 20's really complete the look. If I keep this thing, def going the 20" route. Which do you have? that color is really cool on the black.
Old 09-24-2016, 10:18 PM
Ralcbah's Avatar
2018 E63S
Two more pictures of car lowered with stock wheels. Car lowered on KW springs and Renntech DLM. 10mm spacers in the front, 15 mm spacers in the rear.
Attached Thumbnails W212 e63 lowering-profile.jpg   W212 e63 lowering-0924161840a-1.jpg
Old 09-25-2016, 01:49 AM
a car.
Wheel specs...
Niche Form - M158
20x8.5 ET 34
245/35R20
20x10 ET 40
275/30R20
Currently running 13mm H&R spacers up front.
Old 09-25-2016, 08:25 PM
lexusf's Avatar
2016 E63 S
Is there a way to replace it all? With KW
Old 09-25-2016, 09:03 PM
vcci's Avatar
2014 E63s
Is the ride any different with the spacers? some have reported shaking or other issues with spacers.
Old 09-25-2016, 09:17 PM
  #32
Ralcbah's Avatar
2018 E63S
I've seen posts of others discussing it; not sure if it's been done yet on a w212 amg.
No; I'm happy with them. Was aware before installing that they may degrade ride/drive quality, according to others' posts, and would have removed them if so, but all good. Buy a quality set, and get the proper length lugs, of course, if you go this route.
I've taken it to the strip several times and drive in a 'spirited manner' every day, with no issues post-lowering and spacing install.
Old 09-25-2016, 09:29 PM
  #33
vcci's Avatar
2014 E63s
which spacers did you use?
Old 09-25-2016, 09:32 PM
  #34
Ralcbah's Avatar
2018 E63S
My bad. Should have mentioned...h&r
Old 09-25-2016, 09:42 PM
  #35
vcci's Avatar
2014 E63s
No worries, thanks. I'm assuming no rubbing with that set up.
Old 09-25-2016, 09:48 PM
  #36
Ralcbah's Avatar
2018 E63S
Correct. No rubbing.
Old 09-25-2016, 10:02 PM
  #37
vcci's Avatar
2014 E63s
Just one last question, do you have the part number? H&R website doesn't show an E63 application.
Old 09-26-2016, 08:32 AM
  #38
Ralcbah's Avatar
2018 E63S
I don't, unfortunately. I sourced all of this stuff from Golan at Autotalent; I'm sure they'd be happy to help you figure out part numbers for the spacers and bolts.
Old 09-26-2016, 10:42 AM
  #39
threeMBs's Avatar
Only MBs - the best or nothing
The part numbers are the same as for all CLS (AMG and non-AMG) and for non-AMG E (for some reason they list only E350, but the parts fit E550 and E63).
For the 10mm front - 20556659, for the 15mm rear - 3055665. The difference between "front" and "rear" is that the front spacers have a completely different design due to MB's front dust caps. (For vehicles without front dust caps, same spacers are use for front and rear - without 9 as the last digit in a part number).
The following 2 users liked this post by threeMBs:
DriveTalkCars (04-19-2020), updog (01-04-2017)
Old 10-16-2016, 04:00 AM
  #40
amg444's Avatar
w212 amg e63
Lowering links
Super easy if you have access to a lift. It can be done with a floor jack though. Takes about 5 minutes per side, you may end up doing it a few times until you find the exact ride height you're looking for.
Hey chris, i took your advice in buying lowering links. It arrived in the mail today. Im installing it tomorrow. Do u know of a video that can guide me thru it. Im scared of messing up the self leveling suspension on the e63. Thanks again
Old 10-16-2016, 10:05 AM
  #41
a car.
I've not seen a video, you literally just pop the stock one piece links off, adjust the aftermarket links and pop them on the ball joints. Longer is higher, shorter is lower. Drive the car around for about 5 minutes to let it settle and adjust them as needed. They should have come with an instruction sheet, if not you can find on on KW's website. I think it's in German but the pictures are all you need.
Old 10-16-2016, 10:09 AM
  #42
a car.
Take a look at the last page on this document.
http://www.kwsuspensions.com/extras/...Q/25325044.pdf
BiturboSF (09-04-2020)
Old 10-16-2016, 10:11 AM
  #43
amg444's Avatar
w212 amg e63
Okay tnx chris! Hopefully the rear will be slammed tom👍🏼
Old 10-16-2016, 02:14 PM
  #44
daveenty's Avatar
W212 E63, Modified
Hey guys, only just found this thread and the rear links are something I'm considering doing with mine.
Would it affect the headlamp adjustment on the ILS lights, or would they compensate automatically for the lowering?
Old 10-16-2016, 02:45 PM
  #45
AG6
AG6's Avatar
13 GL550
Are there any performance benefits to changing out front springs besides lowering height? I figured the amg suspension should be adequately tuned.
Old 10-16-2016, 06:32 PM
  #46
a car.
My headlights have adjusted and throw at the same height as before.
Well, it lowers the center of gravity and the KW adjustable springs I use are just a tiny bit stiffer and I feel the make the car handle a bit better.
daveenty (10-17-2016)
Old 10-17-2016, 06:26 AM
  #47
daveenty's Avatar
W212 E63, Modified
What I was hoping to hear.
Thanks for that, links ordered.
Old 10-17-2016, 06:52 PM
  #48
amg444's Avatar
w212 amg e63
Tnx bro apprecite the help👍🏼. U think i should go lower in the rear?😄
Old 10-18-2016, 10:00 PM
  #49
a car.
Glad it all worked out for you brother. Looks great as it sits currently.
Ride around for a few weeks to make sure it's comfortable and there's no rubbing before making any adjustments. Even though the rear is supposed to self adjust for added weight I would get two adults back there and make sure it rides well at the current height.
Old 10-19-2016, 07:30 PM
  #50
AG6
AG6's Avatar
13 GL550
Would 1 inch lowering make a difference to alter center of gravity? Stiffer springs sounds like less comfort.
Quick Reply: W212 e63 lowering
