Wheel Experts..I Need Your Advice
Sup Guys -
I'm considering buying these wheels for my 2002 C32
http://www.oewheelsllc.com/Wheels_3/...3#.Uzueg01OVpg
As you can see they're staggered 18X8.5 and 18X9.5 with 42mm and 44mm offsets respectively.
From the threads I've read the stock 7.5" front has a 37mm offset. Will I be able to squeeze a 235/40 on the front with a 8.5" wheel and 42mm offset?
I'm pretty sure the backs won't fit as the stock offset on the 8.5" wheel is 34mm. Can I fit a 255/35 out back if I run a 10mm hub centric spacer to effectively change the offset from 44 to 34?
thanks!
thanks!
