Mercedes-Benz C-Class W205: Window Tint Modifications
Window tinting is a relatively simple and affordable way to make your classy Mercedes-Benz C-Class w205 even classier. It offers privacy, protection from the sun, and adds a smooth finish to your car's exterior. Whether you want a slight tint or something with more depth, this guide will give you ideas on how to tint your w205 C-Class.
This article applies to the Mercedes-Benz C-Class w205 (2007-Present).
The first step before tinting the windows of your Mercedes-Benz C-Class w205 should be to take a look at your state's laws regarding window tints. They vary from state to state. Different states may forbid tinting beyond a certain level, while others permit tinting in the back windows but not the front. Once you know the law, you can narrow down suitable options for your new window tints. Research the tint laws on Tinting-Laws.com. Generally, slightly darker tints are allowed in states with warmer climates to help protect against the scorching sun heat and rays.
Tinting Windows on a Mercedes-Benz C-Class
The percentage of the window tint corresponds to how much light enters. The lower the tint percentage, the less light that it allows through the windows. So, for example, a tint level of 80% will only allow 80% of light to penetrate it. If you want more privacy or protection against the sun, consider window tints lower than 90%. Smaller tint numbers offer more protection, but some drivers note that it can also interfere with electronic devices such as GPS or other navigation tools. Lastly, keep in mind that window tinting is not as easy as it looks. If you've never tried it or don't have much patience, it is recommended taking your car to a professional.
Light Tint (50%+)
DIY Cost – N/A
Professional Cost – $120 and up
Skill Level– Difficult; leave this project to the professionals.
Most states allow window tints anywhere from 50% or higher. These levels of tint provide enough privacy, sun protection, and adequate visibility for both the driver as well as other vehicles on the road. They still offer UV protection and enough privacy to remain anonymous, giving your C-Class a classy look. These levels are also perfect for most states with window tint restrictions. A tint of 50% and up is recommended for drivers wanting tinted windows with high visibility.
Intermediate Tint (50%-35%)
DIY Cost – N/A
Professional Cost – $300 and up
Skill Level – Difficult; leave this project to the professionals.
According to Tinting-Laws.com, window tints can be over 50% and still be effective against UV rays. However, some drivers still prefer lower percentages. In many states, 35% is the lowest acceptable tint percentage. Refer to your state's tinting laws if you wish to go under 35% as this level of window tint may be considered illegal. Recommended for its high visibility without an apparent dark tint.
Dark Tint (30%-20%)
DIY Cost – N/A
Window tints in this range are quite dark, letting in a small portion of sunlight. Whenever people think of window tint, they usually think of a tint so dark that no one can see inside the car. This is a good way to describe dark tint because it ranges from 35% to 20% visibility, and will only allow a small amount of light to penetrate through the windows. If legal, this option is best for a location with very high temperatures. Recommended for its UV protection.
Super Dark Tint (15%-5%)
DIY Cost – N/A
Professional Cost – $300-$500
This level of window tint is illegal in most states. However, drivers in southernmost states like Texas may be able to get by with this level because the sun is always out. Most drivers avoid tints within this range as they can greatly reduce visibility, and can interfere with certain devices like the GPS navigation systems. This tint is recommended if you plan on using your C-Class as a show car.
Related Discussion, and Sites
- C-Class Window Tint Picture Threads - MBWorld.org
- Tint Regulations and Laws - Tintworld.com
- Local Window Tint Laws - FirstCoastGlassCoatings.com
