190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Towing with the 190E
Old Jul 12, 2005 | 12:01 AM
jballou's Avatar
1992 190E 2.6L
Anyone ever hook up one of those uHaul hitches to tow a trailer?
Old Jul 12, 2005 | 10:36 AM
mctwin2kman's Avatar
Do you want to tow the 190 or tow something behind it? If you want to tow it remember it is a RWD car and towing from the front even with it in nuetral will damage the transmission! I have seen the tranny die completely towing one for a short distance, since the transmission fluid is not circulating. If you need to tow from the front then disconnect the prop shaft! No sense blowing out a perfectly good tranny! I have seen people tow them with the engine running so the fluid could flow somewhat but I would not recommend that!
Old Jul 12, 2005 | 12:18 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
very common sight in europe, especially with the diesel engined models pulling trailers and small boats, haven't seen any 190E's fitted with tow hooks in the US...
Old Jul 12, 2005 | 04:26 PM
jballou's Avatar
1992 190E 2.6L
Sorry- yeah, I meant using the 190E to tow a uhaul trailer, not towing the 190E itself. I'd be driving that bad boy. I just wasn't sure if it would be able to support the hitch or not. Anyone seen this/done this?
Old Jul 12, 2005 | 04:31 PM
I have seen Euro ones with Hitches! So I have to assume yeah it is possible!
Old Jul 31, 2005 | 05:39 AM
Matteus's Avatar
MB, BMW, JEEP & Suzuki
I have a trailer hitch on mine.
it's connected to the rear axle.
I believe on my tech. inspection certificate it says I can tow up to 1500kg braked.
matteus
Old Aug 9, 2005 | 07:16 AM
230TErry's Avatar
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
Not a problem, my dad has been towing touring caravans for about 15 years with his 190E (he's on his 3rd), they have all been manual transmission though. From memory the hitch is fixed to the rear chasis rails and through the trunk floor.
