Dead Car
I don't know if i'm in the right forum, but i have a 260E 1989 and i was driving one day and the car just died, i let it sit for a two days and still dead, i have no idea what it might be, does anyone have any idea what it might be, please i need help. :wall: any help will be greatly appreciated
As "Miracle Max" might say . . ."there's a difference between mostly dead and completely dead."
1) What were the symptoms when it "died". 2) What are the symptoms now, when you try to start. 3) What diagnostic efforts have you made so far? 4) Mileage, date of most recent service, color of interior and what kind of music were you listening to when it expired. |
dead car
it just died on me driving at 30 mph and didn't crank over, it just cranks and thats it, nothing else...i think it might be a relay for the starter ir it just might be the starter. i don't know
dead car
i will thanks
PLEASE GO TO THE W124 FOR MORE INFO. It's your fuel pump relay that is bad. Turn on the ignition and see if you hear a noise from the rear right passanger tire. If you don't your fuel pumps are bad. Also move around the fuel pump relay and see if the car starts or make a noise. It's the one next to the one that says KLIMA
dead car
thanks man
To give you better idea I need more info, but checking for fuel would be a start, you can also check for spark after doing those two check back and let know what happens. Check rotor and cap also. :y
