Radiator Flush Treatments For 190E
Greetings MBworld readers...
The source of my cooling issues is likely the original radiator that has seen Ohio cold and Atlanta heat.
Any recommendations on flush treatments for MB radiators? Its likely pretty gunked up after all these years...
Radiator Drain Plug On 190E
Does it even have a radiator drain? Just want to use this to drain the cooling system after using a flush product
Thanks all! I did a Peak Radiator Flush & Cleaner treatment. Made a big difference in that the temps never get above 90C...I'll repeat this in the fall to fully clean out the radiator....
