Window Problem
Does anyone else have this problem. My rear left window on my 190 E does not roll down. Is there any way I could fix this.
The window lifts are a typical 190E problem, usually the window regulator (lift frame) gets twisted out of shape. Can you hear the lift motor? Is there binding or is it just not budging on the way down? You need to pull the inside door cover off to inspect it.
same problem with my left rear. I don't hear the motor or anything
I hear the motor working, but the window doesn't go down.
