Cold Starting Problems 93 190E 2.6
I'm recently having cold starting problems with my 1993 190E 2.6. If the car sits overnight or is parked for about two hours, it turns and turns for about 15-20 seconds before firing. After it's warm, a quick flick of the key starts it right up. Seems to run normally. Have changed the fuel filter and the plugs, and checked all I could for vacuum leaks. Previous posts indicate the OVP relay could be the culprit, but I can not find the OVP relay on this car. Have also pulled the rubber vacuum hose from the top of the EGR valve with no detrimental effect on the idle. Any suggestions besides bringing it to the (gasp!) dealer?
Thanks; Don
93 190E 2.6
Thanks; Don
93 190E 2.6
