F/S 190e 2.3-16 in NJ
1 Attachment(s)
Hello, everyone.
For sale is my 1986 Cosworth 16v. Just gonna get straight to the point. 1986 Mercedes 190e 2.3-16 Cosworth Upgraded brakes - Brembos in front, upgraded pads and rotors Upgraded suspension - 400e springs, set to appropriate height Upgraded F/R sway bars Custom upper camber plates 2 3/4" piping/exhaust all the way back Motorsport Hardware wheel studs Stock internals Sparco R100s Suede Momo Steering Wheel 17" OZ Ultraleggeras Fire extinguisher mounted in passenger side Wink mirror Roll bar installed by SSI Motorsports Planted seat mounts Semi-stripped interior Sunroof assembly removed, top bracketed and glued in place A/C delete 2.6 bumper bar in front Re-sprayed Smoke Silver by Maaco from previous owner New oil pan and gasket New motor mounts New LCD Lap Timer Screen New battery New alternator New fuel filter New fuel injectors Bosch New power steering filter New valve cover gasket New spark plugs New distributor, cap, rotor New differential seals New steering damper Fresh Motul 600 brake fluid Fresh valve adjustment Fresh oil change Mobil1 15-50 Included with the car will be whatever extra parts I have for it such as extra brakes, spark plugs, relays, some of the interior, white face gauge cluster, etc (too many to list). Car runs and drives great. Can handle turns like a beast. No overheating, no leaks, no rust underneath. All fluids are good to go. The car is track ready. Looking for 7500. For more pictures, this is the link to my original post on Craigslist: http://cnj.craigslist.org/cto/5600425779.html |
I realize this was a while back ... but did this car sell?
