190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
2.3 16 - Charging circuit go through the Volt Gauge?
Old 06-26-2017, 07:52 PM
TTz
TTz's Avatar
2.3 16V / E30 M3 / '72 Pantera / '72 2002
'86 2.3 16. Does the charging circuit go through the volt gauge? My Gauge has gone dead and I am only getting 11.23v (at best) Checked at the battery and from the alternator. I believe the alternator is dying as well, but just want to make sure I am not getting a voltage drop due to the volt gauge being in-op. I did check the input at the gauge and it is only reading low 11's as well, so it would appear the issue is before the gauge.
Thanks and regards;
Tony
Mesa, AZ.
Old 06-27-2017, 10:55 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
To be correct post the VIN!
Old 06-27-2017, 11:22 AM
mrmotoguzzi00's Avatar
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
Tony,
Sounds like the alternator or maybe just the voltage regulator is bad... the regulator should be mounted on the alternator, disconnect the battery then unbolt the regulator...
check the brushes.... should look something like this....
http://www.pelicanparts.com/catalog/..._pg1.htm#item1
if they are unevenly worn than the alternator is on the way out as well...
Mike
TTz (06-27-2017)
Old 06-27-2017, 10:40 PM
TTz
TTz's Avatar
Thank you, Mike. I appreciate your assistance.
I will certainly research the link you provided.
Regards;
Tony
Quick Reply: 2.3 16 - Charging circuit go through the Volt Gauge?
