190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
W201 Vibration problem
Old 08-14-2018, 07:39 AM
joomikseion's Avatar
W201
Hey guys, so ive got this problem that my W201 starts vibrating randomly, it is very loud and wont go away until clutch pedal is pressed and after rolling couple meters or by braking when clutch is pushed down.
It is very random and usually occurs when just driving normally, or by giving throttle when clutch pedal is down. I cant get it to vibrate on purpose. Any suggestions? Ive changed all wheels,rims,engine and tranny mounts, driveshaft bearing and tranny side flexdisk, driveshaft rubber mount. What could it b
Old 09-07-2018, 01:30 AM
razvy's Avatar
190D
Check the drive axles , make sure the CV boots are intact and check for bering play , use a wrench / vise grip and wiggle in all directions .
Old 09-15-2018, 02:59 AM
Zachary Foster's Avatar
91' 190E 2.3 Manual Convert Custom
Rotate your driveshaft back and forth while under the car to check the play in transmission gears and the differential. My friend's 500k+ 2.3l has the differential eating itself alive hitting freeway speeds, causes all sorts of funny noises towards the back.
Old 09-27-2018, 07:19 AM
W201
I noticed today i even heard it when i was at a stoplight. Totally parked with ebrake up, so i could not move so either drifeshaft couldnt move? I heard it at neutral and even when clutch pedal down 1st gear in and in everyway, but i was totally at a stop. When i pressed gas the vibration accelerated so i could hear it even in a higher rate. Exhaust?
Quick Reply: W201 Vibration problem
