Question about the 190E transmission
I have a question about the transmission on the 190 model ?
Where there any 5 speed auto transmission made for the 190 models
I have a 4 speeded auto when I’m going in just right speeds, like 70-100/120 mph there is quote a lot off revs in the engine = noise and gasoline consumption
U know when the price here in Sweden is 5,1 $ / gallon U want to cut down on the gasoline expenses
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
During the production run, all W201's were available with a 5 speed manual transmission. Except for the 16 valve and Evolutions trans (Gertags), the automatics greatly outnumbered the manual in production due to Mercedes typical sales & marketing.
1 Post
Sorry, misread your post. No, there were no 5-speed AUTO transmissions in the W201. The alternative method of changing the gearing would be to swap differentials with a different final ratio. I believe the "taxi" differentials were the more fuel efficient, albeit lower performance, differentials.
Is there any 5 speed auto gearbox from other models that can be suitable for modifying and fitting on a 190E engine
Pic on My Car
Pic on My Car
If you have enough money and time anything is possible. The 190E does not have an electronically controlled tranny! New MB's with the 5 speed auto do! So yes you could do it I suppose, but you would need to fabricate mounts and custom prop shaft since it is probably a longer tranny. Not to mention the electronics, wiring and all the other tidbits. Next you have to make it work with what you already have, which is a car designed to work with a tranny that uses Vacum to do its shifting. It would be sheaper to buy a W202 instead of converting to a 5 speed auto tranny.
