190 2.3-16v Self leveling suspension
Whats up guys, I just picked up an 1986 16v and have a few questions. First issue I'd like to address is the self leveling suspension. The rear suspension seems to be stuck in the up-position, making the rear end stick up higher than it should. This also causes the car to bounce when going over bumps, almost feeling like a pogo stick in the rear. Ive read that this can be caused by an issue with the linkage? Or maybe the valve? Anyone have a similar issue? or know what this can be caused by? Thank you.
Dale |
Unfortunately it’s not as simple as adjusting the sls rod. There are nitrogen cells in the rear suspension, typically when the bladders burst the gas mixes with the fluid causing air to fill in the shocks. The fix fix would be to replace the nitrogen cells drain the sls system and the shocks fill and bleed the system. Use the adjustmet rod rod to set ride height. Expect to to pay a shop about 600-800 to do the service. Hopefully the shocks are still in good condition and they don’t leak. |
Originally Posted by Jc Mendoza
(Post 7610136)
Unfortunately it’s not as simple as adjusting the sls rod. There are nitrogen cells in the rear suspension, typically when the bladders burst the gas mixes with the fluid causing air to fill in the shocks. The fix fix would be to replace the nitrogen cells drain the sls system and the shocks fill and bleed the system. Use the adjustmet rod rod to set ride height. Expect to to pay a shop about 600-800 to do the service. Hopefully the shocks are still in good condition and they don’t leak. -Dale |
Is there anyone in europe (france preferred) that can deal with the SLS system?
thanks, nik |
Originally Posted by Nik Fisher
(Post 8946208)
thanks, nik |
