190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Help Source Fuel Tank
Old Jul 31, 2023 | 12:06 PM
  #176
190Efan's Avatar
1991 190E 2.3
Originally Posted by BetterDaze
awesome dolucasi! I know this issue will come up more and more. My advice is to preserve and recover any fuel tank exit fittings you come across even if you don’t need it someone else might one day.
i never took a picture of my new hose set up but I recovered the exit hose fittings from a used tank and kept my original. That is the most important part of the line it seems, I did try other model hoses since many take the same filter and fuel pumps but they are not positioned the same in each model they will kink or not reach at all.
I took my cracked hose to an industrial hose repair shop and they just removed the OE rubber and replicated the shape and length of it with fresh rubber and clamps on the OE fitting. It is functional and I haven’t had any problems with that part of the car since doing this last October.
Since you actually drive your car infrequently, make sure that you ad Stab-bil Storage to your gas because over a period of time, your gas will turn into varnish. Gas that turns varnish will gum up your engine and fuel system and cause more and significant drivability issues that will be a major pain to resolve.
