Raw gasoline smell after driving...
so my gtr is fine but my GLS makes this smell. My old gl didn’t and they both have M157 engine. I’m not expecting resolution by the way as I’m sure I will get similar responses from dealer.
I also smell gas/burnt oil on my 2018 GTS when I park it in garage, it only has 500 miles on it. It is always after a drive and last couple of hours.
My 2016 GTS started making the smell when it got to about 10K miles. I took it to MB dealer. They kept the car for 2 days and said they couldn’t find anything wrong with it.
Has anyone found any answers or resolution for this?
#32
Years ago, there was a $5M class action lawsuit against MB and it's entire second generation E-Class range including AMGs related to fuel smell/leak.
#33
When you have a chance, go to the thread I created a started of years ago titled GTS PROBLEMS AND ISSUES.
I remember some members posting about this problem.
Also, your MB dealer (Sewell?) should be able to reference this issue in the AMG database maintained in Germany along with the solution.
Best of luck in a quick resolution.
Jerry
Jerry
N-4Speed (03-08-2019)
#34
‘24 BMW iX M60
The smell comes from driver side front fender's vent. There was no smell until it got to about 300 miles and now it is very strong at 500 miles.
My '15 Z06/7 was notorious for a 'burning oil' type smell when at a standstill; it couldn't be smelled when moving. Worse was when I'd just pulled off the highway and came to a red light/stop sign. One way to stop smelling it was to place the HVAC system into 'Recirc' mode, but of course you do not want to run like that the majority of the time. Smell totally resolved when I made sure the dry sump system wasn't overfilled, or was slightly below the top fill line.
I'm not saying the issue is analogous but it's something to check.
Good luck getting to the bottom of this; I know it must be aggravating.
Bish
#35
Guys,
Thank you so much for your feedback! I made an appointment to take it to Park Place MB Tuesday. I will be sure to mention oil level and dry sump holding tank. I will report back once I get a resolution.
California John (03-08-2019)
#36
Please do, as I'd likely take mine in to them as well if they help you find a definitive solution.
#37
Thank you Jerry! I found your post titled: "GTR & GTC ISSUES-OWNER POSTS ONLY PLEASE" but couldn't find the one on GTS. Any chance you could send me a link to it?
#38
My one week old GT R has that smell too, not sure if it’s me getting used to it or it’s less and less strong day after. It’s definitely still there but not as noticeable as the first few days. I now have 426km only, hopefully that smell will be gone soon as mileage accumulates.
#39
‘24 BMW iX M60
Bish
MalibuScott (03-10-2019)
#40
On a brand new car you could be just smelling the brake pads; DCT clutches, etc. ‘breaking-in’. My GT R was the same. It should resolve fairly quickly. Go and drive the snot out of it once everything is warm, and really try and burnish the brakes regardless of what type they are.
Bish
Bish
#41
Bish
Bish
I also checked oil level and it is slightly above the minimum mark.
#42
‘24 BMW iX M60
Bish, I am very familiar with new car break-in smell. This is burnt oil/gas smell concentrated around Driver side front fender where the dipstick is. This is the same smell I noticed when my 2016 GTS got to about 10K miles. Hopefully I 'll report back with some resolution after my dealer visit Tuesday.
Bish
#43
We had it too and the car went back after only two days and the dealer said there is no fuel leak which is what I was concerned with. They claimed it was brake fluid and that after a while it would stop doing it. Well after two months it has gotten less significant but it still lingers for a couple of hours. I think in time it will eventually be completely gone. The main thing is that there is really nothing wrong and that is what I am convinced of. Is it a good thing? No but it's nut ruining our ownership experience.
#44
2020 Huracan EVO AWD - 2022 GLE 63 S Coupe - 2023 C63 S Coupe -
I live in the high desert outside of Vegas. Summer temps are routinely in the 100-115 Fahrenheit range. I have 10k plus miles on my GTR. Even when filling up with gas on my way home on occasion and the car sitting in a very warm/hot garage. I've never smelled anything about what's being talked about here. And yes, I do have a sensitive schnoz when it comes to smell. My best guess is pressure from heat expansion is seeping past a connection (weakest point), evaporative canister or somewhere and causing the issue. Dealer gets the car in and it cools down. Tech may or may not take it for a quick drive. Put it up on a lift. Unless something is visibly leaking or glaring in their face. You get a verdict of normal or NPF (no problem found). This has to be a seeping issue (liquid or vapor) because of pressure from a connection somewhere. If it were an actual leak. It would be pretty obvious/evident.
It might also be possible on a tank that is less than 1/3-1/4 full that fuel expansion on a warmer day may slightly bleed off some vapor pressure once the vehicle is at a rest - just a guess. If you haven't yet. Try keeping the tank at no less than 3/4 full and see if the problem is still there or if it goes away. If it does go away there may be something defective in the EVAP (evaporative emission control system).
California John (03-10-2019)
#45
‘24 BMW iX M60
#46
N-4 Speed
I went back and reread all 20 pages of postings in my topic GTS PROBLEMS AND ISSUES in the Private Lounge.
http://www.mercedes-amg.com/privatel...TS-ONLY/page20
Unfortunately I didn’t find any postings about your specific problem.
There were a few related to brake fluid smell but none about gas smell in the front of the car.
If you haven’t yet you should join the Private Lounge. Many here like me move back and forth between the two sites.
Best regards.
Jerry.
Best regards.
Jerry.
The following 2 users liked this post by JSwan724:
California John (03-10-2019),
N-4Speed (03-13-2019)
#47
No fuel smell. Just an oil smell which started after my first dealer oil change. Attributed that to some spillage that is burning off somewhere. Who knows.... this is related to a slight over-fill of the dry sump tank? Will keep a nose on it.
#48
I'm guessing so, as I have the same issue, but no fuel smell, just burnt oil. Hoping that's all it is anyways.
#49
Impossible to be brake fluid; if they told you that find a new service dept immediately! lol (I may have told you this before). Pads can and do make a smell when the car has been driven hard, the brakes well used and the car parked up without a cool down period. Brake fluid itself is essentially without a smell; (don’t try it as it’s toxic as hell), although if it’s leaking on something hot it might well produce a smell. But then you’d be experiencing major brake issues due to the leak.
#50
‘24 BMW iX M60
Bish
