Second Batch
Second Batch
I was just told by MBUSA's rep that a second batch of GTRs are about to be released. I was not very happy that I didn't get one as part of the first batch but thus is life...
Question I have for everyone is how many people are getting the carbon ceramic brakes?
With the exception of that option, I'm pretty set on what I want.
Now questions for you;
1. release the second batch.... to where and when?
2. Do they know the MSRP yet?
3. What does he know about the current status of the first batch?
Regards
Originally Posted by JSwan724
To answer your question NO on the Carbon Brakes. I won't be tracking my GTR so no because the standard brakes are very good on the street and don't cost a small fortune to replace like the carbon ones do.
Regards
Regards
2. No on the MSRP
3. What do you want to know about the first batch? All the dealerships already have what they have in Netstar. It won't be until the release of the second batch will they know when and how many they will get.
AMG GTR (sadly now sold)+991.2 GT3 RS+GT3 Touring+991 GTS+997 GT3 RS+996 GT3 RS+964 RS+Mini Cooper S
Regards
Regards
I come from the Porsche world where most of us more serious track rats do not get ceramic brakes because of the potential replacement cost. If you are running a race programme, sure you run ceramic brakes, but weekend track guys like me tend to mostly run iron brakes. I have run iron brakes on GT3s lap after lap for the last two years with absolutely no fade.
Indeed, there are more potential down sides to ceramics than up.
- they are extremely expensive to replace
- they tend to squeak when cold
- first applications when cold tend to very grabby until warm
EVO magazine recently ran a test between ceramics and iron brakes on the same car, on the same day and the results showed that there was no difference between the stopping distance of the two after 10 crash stops from 100mph. In fact, the first crash stops on the iron brakes were shorter. Only after 14-15 consecutive crash stops did the ceramcis start to show an advantage and you don't do consecutive crash stops on the race track.
So IMHO, ceramics are total waste of money. If you are a total obsessive compulsive about dust free wheels, then get them, otherwise, save your money.
emericr (01-29-2017)
Originally Posted by GTR3693
It's a urban myth to say if you are going to track the car then you should get ceramic brakes. I wont be getting ceramic brakes precisely because I will be tracking the car.
Members like you are one of the major reasons I participate in this forum.
I get to learn from your experiences about topics where I have little or no experience. THANK YOU for sharing!!
Porsche as compared to Mercedes is an area where there are many here who have both and can share with many here who are like me.
Regards
Regards
Regards
I have cars with steel and CCBs; and I would agree with that in a P car (which I own), CCBs are an over kill.
On the other hand for whatever reason in MB's CCBs are quite an improvement from steel. Maybe because the difference is curb weight?
It would be a good idea to drive a AMG GTs with and without then make your choice.
Breaks, suspension, clutches, tires and tire pressure are all about how they feel to you, kind of like a seat.
Before spending $200K test drive a comparable car, I would get a P car without CCBs any day, but no way I would buy an AMG without CCBs.
I wish you tried the CCBs in the E63, I would bet that you would change your mind.
Indeed, EVery imperical test I have seen clearly shows that any perceived advantage of ceramic over iron brakes inside of 10+ crash stops is purely in the mind. In fact tyres have more of an influence on braking distance than any difference between iron and ceramic brakes.
BTW, nice avatar!
Just one more comment on the ceramic vs iron debate...if you are one of these people who like to take you own wheels on/off, etc....and if you get ceramics....just be very, very careful when you do....because is you accidentally hit your disc during the process, you are potentially toast because ceramics disks chip soooo much easier that iron brake.
As I said, more downs than ups.
Mercedes C200 CGI, CLS350, CLA45 AMG, AMG GTS(ordered)
Just an alternative view on this debate.
CCB significantly reduces unsprung weight and I am staying away from that debate.
My GTS ED1 has the Racing Brakes CCB kit using the OEM calipers. The ceramic rotors can be repaired at a reasonable cost and I still have my OEM rotors and pads.
Promise (01-31-2017)
Does anyone have any suggestions on what type of pads to use for the track on the GT S? I had to replace the stock Porsche pads on my GT 3 to get the right braking and expect that I will need more aggressive ones for the GT S
1 Post
porsche 2017 991.2 TS,GTR amg gla 45 amg 45 amg ,ordering 2019 GTR R cpe
What about the PITA...ceramic burnishing,seating..pad,rotor.....procedure...meth od.???
If you don't follow procedure....there may be issues,how the brakes function...
1 Post
That may be....."no set(MB-GT,s,r procedure)"....I was eluding to the Porsche CCB brakes.
My current Porsche is a 2017-TTS....& that break-in experience,therein...is ARDUOUS,
to say the least.
to say the least.
The GT3 has Brembos and the break-in is happening regularly since pads only last a few track weekends. Not an issue. With CCBs you are correct. Track guys generally prefer steel, unless you are sponsored!! I just need to know: 1) what pads are available and, maybe 2) what other models have the same pad measurements. Amazing how hard it is to get this info from Mercedes
The GT3 has Brembos and the break-in is happening regularly since pads only last a few track weekends. Not an issue. With CCBs you are correct. Track guys generally prefer steel, unless you are sponsored!! I just need to know: 10 what pads are available and, maybe 2) what other models have the same pad measurements. Amazing how hard it is to get this info from Mercedes
janstuart (01-31-2017)
There is no wrong choice here, anyone who tells you otherwise is kidding themselves. People who track a lot tend to not get CCBs because of the costs. However, I prefer the feel of CCBs even at low speeds, I like that they are grabby. As for the squeaky sounds, I have had zero experience with that with my 458 and I have been driving it throughout the winter. I know some people on here swear by the CCBs for Merc, and I personally wouldn't own a sports car without them, but that's because I genuinely prefer them. I suggest trying out a Merc with CCBs and seeing how it compares. No wrong choice here.
