H&R 2055665 10mm spacers won't fit
I have a 2017 AMG GT and tried installing the 10mm H&R spacers in the front part 2055665 and there is a lip/groove inside the spacer that will not allow the spacer to sit all the way flat against the hub. There is about a 5mm or so gap there. Has anyone had this problem? I saw on other threads people have used this part number with no problem and doubt that there is some change in the hub on the 2017 model year but any help would be great.
I successfully installed the +15mm rear spacer 3055665 with no issues whatsoever. |
Not sure it will help you but I had the same problem with a C63 coupe last year. I never quite got to the bottom of how one (or more) users found 10mm hub centric spacers that fitted. I even drew a pic of the problem :)
https://mbworld.org/forums/c63-c63s-...acers-fit.html |
Originally Posted by DragonRR
(Post 7239252)
https://mbworld.org/forums/c63-c63s-...acers-fit.html I think some were able to modify their spacers to fit the snout but I dont like messing with geometry and hubcentric needs when it comes to axles and hubs mounting up to wheels that are going 140 mph or more. |
Originally Posted by Vic55
(Post 7239509)
I fear this is the case for the OP. The problem lies in the snout of the hub (its too long) and shorter spacer will bottom out. Thats why I had to run 18mm square on my C63S (which actually worked out great).
Originally Posted by AMG 17GT
(Post 7239541)
Disregard. Answered in thread.
(Post 7239572)
Why disregard my comment (as if you are in charge here LOL with your vast experience), I was one of the first to comment with the reasons why in the other thread... based on my factual experience. Yes I didnt do a wonderful drawing but I can restate what I have experienced to help the OP here without having him click on link.
Originally Posted by sl600fanatic
(Post 7240451)
Thanks VIC55 for your comments & for following up with me with your fitment advice, truly appreciate all the experience & insight you give to me and others on this forum!
(Post 7239572)
(Post 7240479)
I meant disregard my comment which I erased and edited geez.
he's trying to keep his MB fanatic status by boosting his posts per day count ;)
(Post 7239572)
3055665 H&R +15mm spacers work
So I switched the fronts to the +15mm HR spacers model 305665 and they are a perfect fit. This is the max you can go though guys. It goes right up to the fender with a lowered car. DO NOT try this on a regular suspension car as it will look horrible and give the illusion that the wheels are sticking out.
The front end handling has improved drastically: very stable and precise. Looks wise though here are my thoughts: with the OEM 19/20 wheels, problem with the +15 spacers is that they end us showing too much tire sidewall since they come out so far. I think I will stick to the OEM or have custom spacers built. With the front wheels without spacers, the fenders throws shadow on the top of the tire which doesn't make it seem as high of a profile. If I had 20" in the front, this offset would be perfect for sure. https://cimg0.ibsrv.net/gimg/www.mbw...2b32b1f620.jpg Here is a shot you be the judge: |
any machine shop can shave any amount off a spacer, you have to make sure the remaining spacer will have enough amount of centering and not shave too much of the flange as to make the wheel not fit on it again
Originally Posted by okbarnett
(Post 7248095)
I still think it works, you only shave the face of the spacer, the back / contact to hub has to stay the same , the front face to the wheel is shaved ? 4-5MM ? and that means the flange on the face of the spacer will be now 4/5 mm longer. It may have to be shaved if it wont allow the wheel to seat down on it far enough. I dont know i havent looked inside your wheel to see
PS I would think h&r or somebody already makes a spacer exactly for that car, but I would maching the ones you have, Ive dont it many times, plus cut the lugs down |
(Post 7240479)
(Post 7239572)
https://image.ibb.co/kYNju5/Spacer.jpg Save Save |
(Post 7249439)
it does give a good visual though |
(Post 7249539)
So pretty LOL indeed
it does give a good visual though On a serious note it also makes it clear that there is a minimum hub-centric spacer thickness which you just can't get around without taking (imo) drastic steps. On my C63 neither 10mm or 12mm would seat properly due to the depth of the hub. The only way to make them fit would be to remove the extended hub section which would effectively make them non-hub centric of course or cut the hub itself back which I wouldn't even think of doing. Save |
in the drawing, this shows the hub and its flange. Hubcentric is when the car is designed for the wheel to be centered on the hubs by the flange sticking out of the hub. The lugs dont center anything they just bolt the wheel to the car. The wheel and the hub size match exactly and they must fit togather exactly for the wheel to be centered. otherwise you could never have any balance of the wheels.
In a case like the drawing (take into consideration if its drawn exactly to scale or not) if the spacer is only 5mm or so, you would use a donut spacer, just round disc with no flange because it wouldnt be possible to make one with a flange if it wasnt thick enough to go beyond that flange. And the hub flange would have enough distance left to still center the wheel. At some point you will able to build a spacer that fit on the hub and it is possible to make it thick enough to produce a new flange on it to center the wheel, and you can make what thicknesses you want. Whatever minimum thickness spacers you see for sale that are hubcentric and have flanges is likely the thinnest that can be made for that car In the drawing, that spacer would not be made to fit that hub, its the wrong spacer, never work |
(Post 7250093)
In a case like the drawing (take into consideration if its drawn exactly to scale or not) if the spacer is only 5mm or so, you would use a donut spacer, just round disc with no flange because it wouldnt be possible to make one with a flange if it wasnt thick enough to go beyond that flange. And the hub flange would have enough distance left to still center the wheel. At some point you will able to build a spacer that fit on the hub and it is possible to make it thick enough to produce a new flange on it to center the wheel, and you can make what thicknesses you want. Whatever minimum thickness spacers you see for sale that are hubcentric and have flanges is likely the thinnest that can be made for that car In the drawing, that spacer would not be made to fit that hub, its the wrong spacer, never work The only way round this was to cut down the existing flanges (or) remove the flanges on the spacer itself turning it into a non-hub-centric spacer (or) fit thicker hub-centric spacers or abandon the job (which is the option I went for). So whilst I agree with your comments I'm not sure what they add over the drawing, my comments and comments from others which I *think* make the situation clear.. unless I'm missing something? |
Okay so here is a better photo of my car with the +15mm front H&R spacers: it is perfectly flush with the fender and does not rub:
https://cimg6.ibsrv.net/gimg/www.mbw...0d02cff48e.jpg |
Very nice SL600 :)
I've never done a suspension mod and the one time I tried spacers it was aborted. I really must have a go at some point! |
(Post 7250400)
Very nice SL600 :)
(Post 7250130)
The drawing shows an example (not to scale) of the spacer supposedly designed by H&R to fit the hub of a C63 coupe. The spacer was not thick enough to clear the flange on the car and therefore there was a small gap of about 1-2mm (the drawing exaggerates this).
(Post 7251026)
Brother your pic was spot on the for the issue we are all engaged with whether it be a C63S or a GTS... the shorter ones are not working (that are available) so I, and others, didnt overcook the issue we just got the right ones. I also recommended to the OP in PM's that 15mm will look tremendous with a drop and the picture above is case in point.
(Post 7250204)
