Full Build GTS
I know 100% methanol 'can' be slightly corrosive but it wouldn't say it's highly corrosive. 50/50 water-meth comes out as a mist and is vaporized almost instantly cooling the charge. But I understand your concern..but to me it's really a non-concern. LS guys have been running 100% meth no problems!
NitrousVic (06-28-2018)
I know about that but i dont think it would be a problem. Lets find out.
2021 AMG GLE 63s Coupe AMG GLC 63s Coupe
Also does your ECU tuning have a fail safe tune for when the water/meth injection runs out of liquid or pump/injector failure because they do ?
#39
SPONSOR
www.wheelsboutique.com
I think with your quest for speed it would be worth going with aftermarket wheels to both widen your track and reduce weight.
HRE P101's in those same sizes for example, would come in at sub 9 kg (20 lbs) for the fronts and 10 kg (22.2 lbs) for the rear. That's a rotational weight saving of 9.5 kg (21 lbs) which is equivalent to taking 33.3 kg (73.5 lbs) out of the vehicle.
#42
What are you looking at for your exhaust system on the build? Have you looked into our Capristo System with Cat Delete? If you are unlocking that engine you need to let her sing out the exhaust! Would love to be a part of your build. Drop us a line at Sales@CapristoExhaust.com
https://capristoexhaust.com/product/...-gt-gts-set-1/
#45
My new intercoolers
Much much bigger and have an option for water/meth system. the maximum that gives the place. its nearly plug&play. only need move the water connections.
#46
Looking good, can you please post the link of the shop you got them from?
#49
