Coupe/Roadster
Full Build GTS
Old 03-05-2018, 11:35 AM
300blackout's Avatar
2016 AMG GT-S Edition 1
Originally Posted by ronin amg
After looking at the Weistec water/meth kit you may want to rethink, Methanol is highly corrosive to aluminum and may eat away at the charge cooler cores over time.
The water/meth injectors should be placed in the discharge pipe not the hot side.
I know 100% methanol 'can' be slightly corrosive but it wouldn't say it's highly corrosive. 50/50 water-meth comes out as a mist and is vaporized almost instantly cooling the charge. But I understand your concern..but to me it's really a non-concern. LS guys have been running 100% meth no problems!
Old 03-05-2018, 11:36 AM
AMG 17GT's Avatar
R Nine T
What kind of gains are you expecting with this build ?
Old 03-05-2018, 11:38 AM
MrkiC63's Avatar
MB C63 AMG
@thewb
Front 9x19 11.3kg
Rear 11x20 12.4kg
NitrousVic (06-28-2018)
Old 03-05-2018, 11:44 AM
MrkiC63's Avatar
MB C63 AMG
The goal would be over 1000 at cranckshaft.
Old 03-05-2018, 11:47 AM
MrkiC63's Avatar
MB C63 AMG
I dont use the kit from weistec.
I know about that but i dont think it would be a problem. Lets find out.
Old 03-05-2018, 01:11 PM
ronin amg's Avatar
2021 AMG GLE 63s Coupe AMG GLC 63s Coupe
Do you know what your peak boost pressure will be and do you know exactly how effective the water/meth injection will be at lowering charge temps ?
Also does your ECU tuning have a fail safe tune for when the water/meth injection runs out of liquid or pump/injector failure because they do ?
Old 03-05-2018, 01:53 PM
  #32
MrkiC63's Avatar
MB C63 AMG
I dont know the max boost but i think over 2bar.
The meth system dont need be integrated in software at the moment.
Fuel is not the problem.
Old 03-05-2018, 02:48 PM
  #33
ronin amg's Avatar
Are they not tuning for the fact that the water/meth is an added fuel and not just a charge cooler.
Who is doing the tuning on your car ?
Old 03-05-2018, 03:10 PM
  #34
MrkiC63's Avatar
MB C63 AMG
Yes you can use it for additional fuel with more octan.
GAD Motors do the complete build.
Old 03-07-2018, 02:33 AM
  #35
MrkiC63's Avatar
MB C63 AMG
Thanks capristo
I had my custom made downpipes with heat protection. The rest of exhaust is currently stock. I like it because its not too loud.
Old 03-13-2018, 04:28 PM
  #36
DoctorV8's Avatar
2005 CL65
Subscribed for dyno results!
Old 03-13-2018, 11:42 PM
  #37
nabizzy's Avatar
AMG GTS Solarbeam Yellow
jesus that is one hell of a stable
Old 03-14-2018, 04:12 AM
  #38
MrkiC63's Avatar
MB C63 AMG
Update / Car is runing
Now need drive the car 1000km.
Old 03-14-2018, 10:59 AM
  #39
SPONSOR
thewb's Avatar
www.wheelsboutique.com
@thewb
Front 9x19 11.3kg
Rear 11x20 12.4kg
I think with your quest for speed it would be worth going with aftermarket wheels to both widen your track and reduce weight.
HRE P101's in those same sizes for example, would come in at sub 9 kg (20 lbs) for the fronts and 10 kg (22.2 lbs) for the rear. That's a rotational weight saving of 9.5 kg (21 lbs) which is equivalent to taking 33.3 kg (73.5 lbs) out of the vehicle.
Old 03-19-2018, 07:51 AM
  #40
MrkiC63's Avatar
MB C63 AMG
Car is running fine
Old 03-24-2018, 03:26 PM
  #41
MrkiC63's Avatar
MB C63 AMG
1500km are done. Need oil change and final software.
Old 05-13-2018, 08:14 PM
  #42
Kvn22's Avatar
22 (WIFE) & 23 G63,22 TOYO TUNDRA TRD,21 GT BS, 22 McLaren GT,23 DUCATI MULTI V4 PIKES PEAK, 23 S580
Cool
Originally Posted by Capristo
What are you looking at for your exhaust system on the build? Have you looked into our Capristo System with Cat Delete? If you are unlocking that engine you need to let her sing out the exhaust! Would love to be a part of your build. Drop us a line at Sales@CapristoExhaust.com
https://capristoexhaust.com/product/...-gt-gts-set-1/
$5K for your system? YIKES
Old 05-31-2018, 03:09 AM
  #43
MrkiC63's Avatar
MB C63 AMG
Here a little video
The following 2 users liked this post by MrkiC63:
emericr (05-31-2018), MBzW205 (05-31-2018)
Old 06-25-2018, 08:34 AM
  #44
MrkiC63's Avatar
MB C63 AMG
My best half mile run was 173mph
I hope i beat that soon.
Old 06-27-2018, 04:24 AM
  #45
MrkiC63's Avatar
MB C63 AMG
My new intercoolers
Much much bigger and have an option for water/meth system. the maximum that gives the place. its nearly plug&play. only need move the water connections.
Old 06-27-2018, 10:06 AM
  #46
Kvn22's Avatar
Looking good, can you please post the link of the shop you got them from?
Old 06-27-2018, 11:49 AM
  #47
MrkiC63's Avatar
MB C63 AMG
Please contact GAD Motors directly. They will help you.
Info@gad-motors.de
Tel: +49 (0) 711 55 34 63 97
Old 06-27-2018, 07:34 PM
  #48
emericr's Avatar
2021 Porsche TTS
looking great. Are you going to install their meth kit?
Old 06-28-2018, 02:32 AM
  #49
MrkiC63's Avatar
MB C63 AMG
Thank you
Yes, a meth kit is always a good solution. It protects the engine and always keeps it clean.
Old 06-28-2018, 10:25 AM
  #50
dbasons55's Avatar
My new intercoolers
looks good bro 👌🏼 Good luck this weekend in the half mile event
Quick Reply: Full Build GTS
