R03 Extreme-Performance Sport Tires
Does anyone know if these are still available for the 2019? When I built/ordered mine, the salesman said he could not find any option for it like the 2018's.
I was thinking maybe they made them standard for 2019 on the GTR's, but when you go here-
https://www.mbusa.com/mercedes/vehic...nt=model-specs
It shows tires sizes as 275/35ZR19 front and 325/30ZR20, which are not the R03's that are from the corvette Z007
Thanks.
Thanks.
‘24 BMW iX M60
The R03 option is not available for order/delivery in the USA; your salesman should know that. But never fear, as the R03 tyre is simply this:
https://www.tirerack.com/tires/tires...oModClar=Coupe
The Michelin Sport Cup 2 ZP tyre that is OEM on the Z07 version of the C7 Z06.
thebishman (08-03-2018)
My car's build sheet listed the R03 option. Did not come with the tires. But I did install the Z07 SC2's last week, going to the track Monday.
They look awesome, much less tread and less tread depth. But seem to be very noisy.
‘24 BMW iX M60
That is not true to the best of my knowledge:
The OEM tyre everywhere the car is sold is the Michelin Sport Cup 2. It comes standard on the car and is NOT the R03 option tyre.
The R03 option tyre which is the SC2 ZP tyre, is only allowed to be sold by MB in certain countries of which the USA is not one of them.
My car also was ordered with the R03 ‘option’, but as the ZP tyre can’t be delivered on the GTR in the USA, every car ordered that way was simply delivered with the ‘normal’ SC2 instead. The same tyre it would have been delivered with even if the R03 option hadn’t been specified.
Bish
Bish
‘24 BMW iX M60
Check this out:
http://www.mercedes-amg.com/privatel...-Sport-Cup2-ZP
It specifically lists the very limited number of countries where MB will actually equip the GTR with the ZP tyre If ordered that way.
Bish
Bish
Former Vendor of MBWorld
our DOG's list the regular (non spec 1448) Cup 2 tires as standard on a GTR, optional on other GT cars
RXC19”/20” AMG Performance Forged Twin 5-Spoke Black R03, B51 Option price: $1,700 GTR only
no.. thats the spec 1448 for Corvette grand sport and Z06 cars.. both ahve to have the Z07 package ... but once your non ZP cup2's are done you can get them from tirerack or wherever..
that ZP tire I can tell you does not last nearly as long as the regular Cup2's.. on track you have about 3-4 good laps on them per session before they really heat up, a couple more are ok... but then its understeer city lol.. maybe its me. Car & Driver said after a few laps they can get a great time, but another couple and they are losing over a second a lap...
I was at summit Shenendoah and its hard on brakes and tires and I can attest to it.. smoked a GT3 911 early on in a session... but halfway through he was gaining and I was understeering (granted Ive done three track days on that set )
Honestly the non ZP tires arent bad at all.. maybe better for most people
‘24 BMW iX M60
Shalul,
The OEM tyre for the GS and Z06 is the MPSS Michelin Pilot Super Sport, not a Sport Cup 2. The SC2 ZP tyre; which is the R03 option tyre that we can’t get the GT R delivered with here in the US, is the OEM tyre for the Z07 optioned Z06.
It it takes me about two laps to get the ZP tyre up to temp and then it’s great for about 4-5 laps. Only the last lap or two does it tend to get a little ‘greasy’.
What pressures res are you running them with?
As for cost: you have to pay to play!! lol
Bish
Bish
Shalul,
Bish
Bish
I was running 28psi
‘24 BMW iX M60
[QUOTE=susman@eurogermantown.com;7524725]yea your right Supersports standard.. w/Z07 package you get the cup2zp
I was running 28psi[/QUOTE
Thats too high Shalul. Start around 24/25 cold and you should end up around 32/33 hot. Try it and see if they ‘last longer’ for you.
Bish
Bish
susman@eurogermantown.com (08-09-2018)
[QUOTE=thebishman;7524995]Agreed. If you are starting at 28psi and pushing a 3700 lb car really hard you were probably 40+ hot. Any performance street tire when push hard on the track is going to jump 10*.
[QUOTE=BenzGTR;7525102]
It goes up and I bleed it off after each session.. but I'll try it lower
Ok will try thanks Bish!
thebishman (08-09-2018)
[QUOTE=susman@eurogermantown.com;7525136][QUOTE=thebishman;7524995][left]
Check pressures, RIGHT off the track. And if you do a cool down lap, I'd add about 4 psi to what your are seeing. Meaning if you do a cool down lap and come off seeing 36psi, it was really 40+
susman@eurogermantown.com (08-10-2018)
‘24 BMW iX M60
These were just released by Michelin. They are sized for the C7 Corvette Z06 and hence are slightly larger than the OEM Sport Cup 2’s that the GT R comes standard with in the US, but they are the exact same size as the R03 option tyre that the rest of the world can order on the car. I can personally tell you that this size tyre fits perfectly as I’ve run the MP SC2 ZP tyres on track three times, and they are the exact same size as these A/S 3 tyres.
Here you go:
Btw these are Run flat tyres
Scott Siddall (09-20-2018)
Here you go:
Great info....thanks a ton. GTR still sitting in port in Germany but when it's done, I'll post a photo.
