Rusty rear rotor hat, any ideas?
I love my AMG GT, but my rear rotor hats are rusty. When I have inquired about this I have been told that this just happens. Online I have seen people paint the area with high heat engine paint. I have also seen the suggestion of covering with brake dust shields. Has anyone else had this problem? What did you do? Who helped you resolved the issue? It’s a first class problem to have, but a solution would be good.
That’s gonna happen if you live in a damp climate and don’t drive much. Daily use “rubs” the rust off.
You can take the wheels off and scrub it off with dilute acid like white vinegar but it will come back if the car sits around and not using it. Don’t paint it. The paint will rub off and then you’ll get a mess.
Two options:
Drive it more often or
Switch to CCBs
Two options:
Switch to CCBs
Two options:
Switch to CCBs
Two options:
Switch to CCBs
‘24 BMW iX M60
Two options:
Switch to CCBs
Two options:
Switch to CCBs
The hats never get touched so surface rust is kinda normal but in general the rotor should be coated and not do that much rusting.
I would suggest painting, there is brake caliper paint designed for higher heat than engine paint I would use, follow the instructions and it will be fine.
You could, worst case, buy new rotors, paint them, then have them installed by any shop or your dealer.
Great news, I found a place that will powder coat these rotor hats! While my Mercedes dealership was not helpful, I called a local Ferrari dealership and asked if they had any reputable recommendations. They suggested Auto Art, a custom body shop in my area. I went there and I felt like I was no longer speaking a foreign language. I plan to get these done on Monday after the holiday! I am also putting on my winter setup at the same time as well.
Thanks all for the advice to keep looking!
rotors have thin paint. I do this to every car I own. Find a similar color paint, or gray primer usually matches pretty well. wet sand it, and the outside of the rotor where the air vents the internal area of the rotor, wash it all and clean with detergent. Spray it while rotating the rotor, you can mask the face, but overspray will come off first time you press the brakes so its not necessary.
then it will wash off easier and look new all the time.
Mission accomplished, this turned out great and looks so much better! Thanks for all of the advice. This photo is also with my winter wheel setup. Auto Art does great work and provides great service.
thebishman (11-29-2018)
