2020 AMG GT DOG
2020 official info
Standard Equipment
P44 –Parking Package –Now includes a Front Camera
U88 –AMG Drive Unit Steering Wheel Controls
U78 –AMG Performance Exhaust will now be standard for all GT Roadsters
NTG 5.5 including Apple CarPlay, Android Auto, and AMG Track Pace
New 12.3” fully digital instrument cluster
New 10.25” multimedia center display
Newly designed high performance LED headlights
NewOptionalEquipment
446 –Touchpad only option (replaces control knob on center console)
568 –Exclusive NappaLeather in Silver Pearl/Black with Diamond Stitching (GT C only)
644 –designoBrilliant Blue Magnoexterior color
RXN –New Y-Spoke design wheel in titanium gray (GT only)
RXQ –New Split 10-Spoke forged wheel in titanium gray (GT C only)
RXR –New Split 10-Spoke forged wheel in black (GT C only)
NewLimited-Edition GT R PRO
Limited to 150 units in the US
Manually adjustable coiloversuspension
Standard Carbon Ceramic Brakes, Exclusively painted black with white lettering
Functional “gills” on front fenders
Larger front splitter with aluminum supports providing greater front axle downforce
Adjustable Carbon Fiber Stabilizer Bar on front axle
Exclusive Carbon Fiber Roof
Standard Matte Carbon Fiber Interior Trim and Crossbar, Carbon Fiber Package I, and Carbon Fiber package II
-shahul
Performance & Handling
Handcrafted AMG 4.0L V8 biturboengine
AMG SPEEDSHIFT® DCT 7-speed transmission
AMG High-Performance Composite Braking System
AMG Performance seats
NextGeneration AMG Performance steering wheel
AMG DYNAMIC SELECT
AMGDrive Unit Steering Wheel Buttons
Automatically-deployedrear spoiler
AMGSport Suspension
3-stage ESP®
Summer Performance Tires
AIRPANEL Active AerodynamicSystem for enhanced cooling
Rear Differential, AMG mechanical limited-slip (GT only)
Rear Differential, AMG electronic limited-slip (GT C only)
14.2” Front & Rear brakes with Silver-painted brake calipers (GT)
15.4” Front & 14.2” Rear brakes with Red-painted brake calipers (GT C)
Absorbent glass matbattery (GT only)
Lithium-ion battery (GT C only)
AMG Performance Exhaust System
AMG RIDE CONTROL Sport Suspension with 3-stage adjustment(GT C)
Comfort& Convenience
Power/Heated/Memory AMG Performance seats
4-way power steering column
AMG stainless steel door sill covers
MercedesMeConnect with trial period
Power/Memory/Dimming/Folding mirrors
Rear load space cover and cargo net
Trickle charger prewiring (includes accessory trickle charger)
COMAND®Navigation
Dual-zone climate control
Active LED Headlamps with IntelligentHigh Beam Control
AMG Track Pace
NTG5.5 with Apple CarPlayand Android Auto
AMG Performance steering wheel -Full Nappa(GT)
AMG Performance steering wheel -Full DINAMICA (GT C)
4-speakersound system (GT only)
Burmester® Surround Sound System(GT C)
KEYLESS-GO®(GT C)
Affalterbachcrest pressed into center console lid (GT C)
ExclusiveNappaLeather Interior (GT C)
AMG Illuminated Door Sills (GT C)
Fixed Panorama Roof (GT C)
Heated/VentilatedSeats (GT C)
10.25” Multimedia center display
Safety & Security
Rearview andFront Cameras
PRE-SAFE®System
ActiveBrake Assist
8 Standard air bags including driver and passenger knee air bags
PARKTRONIC®
Lane Tracking Package (GTC)
Standard Equipment for GTR
Next Generation AMG Performance steering wheel
AMG DYNAMIC SELECT
19”/ 20” AMG Forged Wheels
Fixed rearspoilerand enhanced aerodynamics
9-Mode AMG TRACTION CONTROL
Michelin PilotSport Cup 2 Tires
Lower Carbon Fiber aerodynamic profile for enhanced traction
15.4” Front & 14.2” Rear brakes with Yellow-painted brake calipers
Yellowbrakecalipers
Active rear-axle steering
Carbon fiber roof panel
1” wider wheels/tiresfront and rear
Carbon fiber drive shaft and torque tube
MercedesMeConnect-withtrial period
COMAND®Navigation
Dual-zone climatecontrol
AMG Track Pace
4-speaker sound system(for weight reduction)
Safety & Security
Rearview and FrontCameras
ActiveBrake Assist
PARKTRONIC®
The new limited-edition AMG GT R PRO is characterized by further improved driving dynamics, in particular on the racetrack. Experience gained from the AMG GT3 and AMG GT4 racing cars was influential in its development, and no other current production Mercedes-AMG is as close to motor racing as the new AMG GT R PRO.
The new AMG coil-over suspension offers even more choice for tailoring the set-up to the particular track. As in professional motorsport, the driver is not only able to set the spring preload length mechanically, but can now also adjust the compression and rebound of the dampers. This is done quickly and precisely without tools via a click system with an integrated adjustment dial on the damper.
The AMG GT R is already fitted with Uniballspherical bearings at the lower wishbones of the rear axle. The AMG GT R PRO now gets these bearings also for the upper wishbones. They are significantly more wear-resistant than conventional wishbone bearings and due to their design have no play, which means toe-in and camber do not change even under high loads. As a result, the AMG GT R PRO can be driven with even more precision.
In addition to a host of carbon-fiber components, weight is saved by making the ceramic composite high-performance braking system standard. And exclusively for the AMG GT R PRO, the brake calipers will be painted black with white lettering.
Aerodynamic fine-tuning increases the overall performance of the AMG GT R PRO as well. The redesigned front apron was fitted with two flics at the sides made of clear-coated carbon fiber. The lower flics transition virtually seamlessly into the front splitter, which was extended further forward and is held by small metal braces that stabilize the front splitter at higher speeds. The air slots, or gills, in the front fenders effectively vent the wheel arches and contribute to reducing front-axle lift. At the rear, a clear-coated carbon-fiber aero element at the wheel arch on either side rises up vertically almost to the level of the tail lights. The combination of all these measures significantly reduces front-axle lift without negatively impacting the aerodynamic conditions at the rear axle.
The AMG GT R PRO doesn’t only drive like a racing car, it also looks the part. The standard Carbon Fiber Packages I and II with front splitter, fins in the fenders, trim strips in the side sills, side mirrors, rear spoiler, and a diffuser with high-quality clear-coated carbon-fiber finish emphasize the racing inspired design and performance. Additionally, the carbon-fiber roof has been redesigned with a lowered center exclusively for the AMG GT R PRO.
Even before the world premiere, the new AMG GT R PRO has impressively demonstrated its performance potential on the racetrack: In early November, AMG brand ambassador and AMG GT3 racing driver MaroEngel completed a circuit of the NürburgringNorth Loop in exactly 7.04.632 minutes driving a still disguised AMG GT R PRO. This considerably bettered the previous time for the AMG GT R and demonstrated the great potential of the current AMG flagship model.
ALSO, how does your US version 2019 GTR have the Track Pace App activated?
Regards.
