Water leaking into trunk
Hi all don’t suppose anyone had any problems regarding water leaking into trunk,think this is why my rear sub is not working as well any help on this would be much appreciated thanks?
Simon0808 (03-22-2019)
I had water issue in the trunk with my 2016 GTS after they replaced the mechanism the raises/lowers the rear spoiler. I noticed that after a car wash or rain, I would get water in the trunk. There are 2 black oval plastic plugs that you will see if the spoiler is up. Somehow they didn't put the plugs back in after they performed the repair. to test, I used electric tape to cover the 2 holes and run it through the car wash and no water. I took it back and sure enough, they said the plugs were missing.
California John (03-23-2019)
This is also more serious then you might first think. I was using the car for months and it's only because of a very rainy LA winter that something under that unplugged hole filled up with water, corrupting a sensor, and thereby kept the parking break permanently engaged.
