New OBD port Renntech tune
While checking out the Renntech site, I noticed you don’t have to send in your ECU in for tuning any more.
You can seitch from stock stock and new tune as often as you want. Like trips to Dealer .
any input on this? And it’s cheaper . Tune from hand held is $2980
I went with the Renntech HHT. It is very easy to use the OBD2 port. Simply insert your key in the glovebox switch, turn to position 2, insert the HHT in the OBD2 port and wait for the tune to upload.
Beeast (05-28-2021)
Yes, it does make driving the GTS more "robust." I used to avoid using comfort mode, which now is better. Sounds weird I know---but put it this way. On my 2018 AMG E63S, the car is quite responsive even in comfort mode. The Renntech tune makes the GTS more responsive even in comfort mode, which I used to avoid.
The Renntech HHT is more expensive, but there is some comfort in the reputation and at least informal relationship with MB. I don't think the "numbers" produced are necessarily the biggest factor in selecting a tune, but driveability of the vehicle certainly should be. And here the Renntech HHT works.
There is an available Renntech HHT for my 2018 AMG E63S, but right now I am not inclined to go that route as I find the smoothness of this vehicle as a sedan makes it already too easy to find yourself cruising at ticket speeds. In the GTS, you know when you're going fast. ; )
Ken
Ken
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
OBD2 tuning has been out for the M177/M178 for a bit now- its the same discussion as before but with a different delivery system. So the age old question comes right back:
Which tune and how much to pay for shelf tune? Will this affect my warranty?
So maybe I should just redirect this thread
I think if an individual is "risk adverse"---keep it stock and avoid aftermarket tunes and modifications. My GTS is nearly out of warranty anyway, so I've got that going for me---lol. I'll switch back to the stock tune next month since I have a service scheduled and see what happens at the dealer.
Renntech seems to be more expensive than other similar HHT offerings---the Renntech HHT is about $3K.
I think the main question is: How much does it cost to replace my AMG GT/GT-S/GT C/GT R engine if something goes wrong? It's really amount the amount in dollars of risk, not simply that there is risk. How much can you afford to bet.
Ken Doo (03-25-2019)
‘24 BMW iX M60
Ken
Ken
Decartesfool makes a valid point: what is your ‘pain’ threshold to having a caned tune installed when a destroyed engine on a GT/GTC/GT R might run you, what? $50K-$70K to replace?
I know a friend of mine who had a tune on his 178 series engine that had a catastrophic engine failure that required the replacement of the entire motor. There is no indication if the tune caused the failure or some other factor did, so can't blame the tune or anything else specifically. But the cost would have been astronomical had Mercedes not covered it under warranty. Dealer never said what was the cause of the failure.
These things have and can happen so buyer beware. If you want to play just be prepared to pay. If your good with that then mod away.
I'm sure Eurocharged has a cheaper and more reliable tune, which is most likely what i'm going with since i've heard more about them.
