'16 AMG GTS Navigation (COMAND)
Hey all...I've taken about a 5 year break or so from MBs (at least ones worth being on the forum to discuss), but am back with a 2016 AMG GTS...it's currently shipping to me from Illinois to Germany, and I've searched long and hard for navigation information; to no avail.
My wife has a GLA250 (US Spec) that we picked up--and was able to secure an SD card with all of the European countries on it (democratic ones, at least). I checked with the same shop for one for the GTS, and was told they don't exist. Leads me to believe there is a harddrive map system for the GTS; could somebody confirm? Also, if so, do you believe a German dealer will be able to update the hard drive at a cost, or will I have to replace the entire system? I ask, because on the mercedes site, it only lets me pick USA/CAN for Map Updates--so wondering if they aren't compatiable in Europe with these cars--whereas the SD format can be updated easily.
Thanks for the help in advance!
Super Moderator
Received 3,171 Likes
If memory serves, the CLA is using TomTom for navigation and requires the SD card purchase to activate navigation in the car.
For the GT you should be able to just go to a German MB dealer which can update comand system to the European maps, which should be done via USB (stick).
They will I’ll likely charge you unless you can convince them that it could be part of the 3 year free map updates (if within 3 years of first purchase).
Good luck!
Good luck!
Good luck!
Good luck!
Lifted G500, GT-S, track Cooper S
Correct on the USB upload to the hard drive. Once you have it, the dealer can check your vin to see if you have the most current version, as each download is tied to the VIN and a unique PIN. The
Thanks much. I came across a UK website that said it would be roughly £268 or $325+ for the stick and the pin code. Is this in line with what a dealer may charge? Didn't realize how lucky I was with my $40 SD card for my wife's GLA 😳
