Report No.:D0095810670
Inspection Report
This report is created by
LAUNCH
Vehicle Information
VIN:WDDHH8JB4GB333610
Vehicle manufacturer/model: Mercedes/E-Class E350-4M
Year of manufacture: 2016
Odometer:110136
Vehicle Software Version:V50.36
Inspection Organization
Name:
Address:
Contact Number: 8312524115
SN:960744005203
Time and date of inspection:2025-11-11 17:57:09
Inspection Result
There are 3 issues for Power system:
1.The power supply is too low._
2.The actuation for the switchover valve of the intake manifold (cylinder bank 2) has a short circuit to positive._
3.The actuation for the switchover valve of the intake manifold (cylinder bank 2) has an electrical fault or an open circuit._
There are 10 issues for Safety and Security system:
1.Input ''Circuit 30'' has a malfunction._
2.The CAN message from control unit ''Electronic stability program'' is faulty.
3.The CAN message from control unit ''S1 (Electronic ignition lock (EIS))'' is faulty.
4.The CAN message from control unit ''Electronic stability program'' is faulty.
5.The CAN message from control unit ''Engine electronics'' is faulty.
6.Chassis CAN bus:CAN signal ''Engine torque'' from control unit ''Engine electronics'' is implausible.
7.Check codings in control unit ''S1 (Electronic ignition lock (EIS))''.
8.CAN communication with control unit ''A1 (Instrument cluster)'' has a malfunction.
9.Chassis CAN bus:CAN signal ''Brake request'' from control unit ''Electronic stability program'' is implausible.
10.The output for the window heater has a malfunction.There is an open circuit.
There are 8 issues for Vehicle body system:
1.The power supply of circuit 30g is < 7.5 V._
2.The power supply of circuit 30 is < 7.5 V._
3.The power supply of circuit 30g is < 8.5 V._
4.The power supply of circuit 30 is < 8.5 V._
5.The power supply of circuit 30g is outside the valid range.The limit value for electrical voltage has not been attained.
6.The power supply is outside the valid range.The limit value for electrical voltage has not been attained.
7.The output for the central locking motor has a malfunction.There is an open circuit.
8.The output for the central locking motor has a malfunction.There is an open circuit.
There are 1 issues for Infotainment system:
1.The connection with the control unit for telematics services cannot be established._
Inspections are normal for Power system
1.TCM - Transmission Control Module
2.ISM - Shift module(A80)
Inspections are normal for Chassis system
1.AIRMATIC - AIRMATIC(N51/3)
2.TPMS - Tire Pressure Monitoring System
Inspections are normal for Safety and Security system
1.IRS-HLA - Outer Left Rear Intelligent Radar Sensor system(B29/4)
2.RFK - Backup Camera
3.RevETR_RF - Right Front Reversible Emergency Tensioning retractor(A76/1)
4.IRS-HRA - Outer Right Rear Intelligent Radar Sensor system(B29/5)
5.SRS - Supplemental Restraint system(N2/10)
6.SCCM - Steering Column module(N80)
7.ESP(R) - Electronic Stability program(N30/4)
8.RevETR_LF - Left Front Reversible Emergency Tensioning retractor(A76)
Inspections are normal for Vehicle body system
1.COU[ZBE] - Audio/COMAND Operating Unit
2.Driver-side SAM - Front Signal Acquisition And Actuation module(N10/1)
3.IC - Instrument cluster(A1)
4.LIN: N110 - Weight sensing system (WSS)
5.PTG - Power Tail Gate(N121/1)
6.LIN: B38/2 - Rain/light sensor(RGLS)
7.LIN: B95 - Battery sensor(BSN)
8.DCU_RR - Right Rear door(N69/4)
9.CGW[ZGW] - Central gateway(CGW[ZGW])
10.SG-SW-L - Left Headlamp
11.LIN: A70/1 - Analog clock(AU)
12.SD - Control Module Sliding Roof
13.KG - KEYLESS GO(N69/5)
14.LIN: S16/12 - Lower control panel 2(LCP)
15.LIN: M6/1 - Windowshield wiper(Windshield wiper FSW)
16.ESA'Front Passenger' - Electric Seat Adjustment 'Front passenger'(N32/2)
17.ESA 'Driver' - Electric Seat Adjustment 'Drive'(N32/1)
18.LIN: A67n2 - Garage door opener(GTO)
19.EZS - Electronic Ignition lock(N73)
20.AC - Air Conditioning(N22/7)
21.DCU_LR - Left Rear door(N69/3)
22.LIN: S77 - Lower control panel(LCP)
23.LIN: E1n7 - Actuation module, LED exterior lighting, left front(AMLAB-L)
24.SG-SW-R - Right Headlamp
25.LIN: E2n7 - Actuation module, LED exterior lighting, right front(AMLAB-R)
26.LIN: A67 - Dimming inside rearview miror(AISP)
Inspections are normal for Infotainment system
1.ZAN - Audio/COMAND display(A40/8)
2.KOMO/mbrace - Communication Module'Telematics Services'/Emergency call system
3.TV - TV tuner(A90/1)
4.SOUND - Sound system(N40/3)
Professional Report
Disclaimer
This inspection report is for reference only. All data provided in this report is based on static data, detailed dynamic and/or live diagnostic data should be generated by a professional maintenance tool. Launch is not liable for any fault or accident caused thereby.
