Created by OBDLink - OBD Solutions | www.obdsoftware.net |
Name | Continuous | Available | Complete |
Misfire | Yes | Yes | Yes |
Fuel System | Yes | Yes | Yes |
Components | Yes | Yes | Yes |
Catalyst | No | Yes | Yes |
Heated Catalyst | No | No | No |
Evap System | No | Yes | Yes |
Secondary Air System | No | Yes | Yes |
AC Refrigerant | No | No | No |
Oxygen Sensor | No | Yes | Yes |
Oxygen Sensor Heater | No | Yes | Yes |
EGR System | No | Yes | Yes |
ECU | Code | Type | Status | Description |
10 | P0101 | PowerTrain | Confirmed | Mass or Volume Air Flow Circuit Range/Performance |
10 | P0301 | PowerTrain | Confirmed | Cylinder 1 Misfire Detected |
10 | P0303 | PowerTrain | Confirmed | Cylinder 3 Misfire Detected |
10 | P0302 | PowerTrain | Confirmed | Cylinder 2 Misfire Detected |
10 | P0304 | PowerTrain | Confirmed | Cylinder 4 Misfire Detected |
10 | P0305 | PowerTrain | Confirmed | Cylinder 5 Misfire Detected |
10 | P0300 | PowerTrain | Confirmed | Random/Multiple Cylinder Misfire Detected |
10 | P0151 | PowerTrain | Pending | O2 Sensor Circuit Low Voltage |
10 | P0131 | PowerTrain | Pending | O2 Sensor Circuit Low Voltage |
PID | Description | Value | Units |
SAE 0x03 | Fuel system 1 status | 1 | |
SAE 0x03 | Fuel system 2 status | 1 | |
SAE 0x04 | Calculated load value | 0 | % |
SAE 0x05 | Engine coolant temperature | 183.2 | F |
SAE 0x06 | Short term fuel % trim - Bank 1 | 0 | % |
SAE 0x07 | Long term fuel % trim - Bank 1 | -28.12 | % |
SAE 0x08 | Short term fuel % trim - Bank 2 | 0 | % |
SAE 0x09 | Long term fuel % trim - Bank 2 | 34.38 | % |
SAE 0x0B | Intake manifold absolute pressure | 0 | inHg |
SAE 0x0C | Engine RPM | 0 | RPM |
SAE 0x0D | Vehicle speed | 0 | MPH |
SAE 0x0E | Ignition timing advance for #1 cylinder | -54 | deg |
SAE 0x0F | Intake air temperature | 104 | F |
SAE 0x10 | Mass air flow rate | 0 | lb/min |
SAE 0x11 | Absolute throttle position | 5.1 | % |
SAE 0x12 | Commanded secondary air status | 4 | |
SAE 0x13 | Location of oxygen sensors | 51 | |
SAE 0x14 | O2 voltage (Bank 1, Sensor 1) | 0.47 | V |
SAE 0x14 | Short term fuel trim (Bank 1, Sensor 1) | 0 | % |
SAE 0x15 | O2 voltage (Bank 1, Sensor 2) | 0.47 | V |
SAE 0x15 | Short term fuel trim (Bank 1, Sensor 2) | 99.22 | % |
SAE 0x18 | O2 voltage (Bank 2, Sensor 1) | 0.47 | V |
SAE 0x18 | Short term fuel trim (Bank 2, Sensor 1) | 0 | % |
SAE 0x19 | O2 voltage (Bank 2, Sensor 2) | 0.47 | V |
SAE 0x19 | Short term fuel trim (Bank 2, Sensor 2) | 99.22 | % |
SAE 0x1C | OBD requirements to which vehicle or engine is certified | 1 | |
Aux 0x00 | Input voltage read by the scan tool | 12.1 | V |
0x02 | Freeze frame DTC | P0300 | |
0x03 | Fuel system 1 status | 2 | |
0x03 | Fuel system 2 status | 2 | |
0x04 | Calculated load value | 63.92 | % |
0x05 | Engine coolant temperature | 116.6 | F |
0x06 | Short term fuel % trim - Bank 1 | -25 | % |
0x07 | Long term fuel % trim - Bank 1 | -23.44 | % |
0x08 | Short term fuel % trim - Bank 2 | 23.44 | % |
0x09 | Long term fuel % trim - Bank 2 | 33.59 | % |
0x0B | Intake manifold absolute pressure | 22.44 | inHg |
0x0C | Engine RPM | 2700 | RPM |
0x0D | Vehicle speed | 23.61 | MPH |
Sensor | Available |
Bank 1 - Sensor 1 | Yes |
Bank 1 - Sensor 2 | Yes |
Bank 1 - Sensor 3 | No |
Bank 1 - Sensor 4 | No |
Bank 2 - Sensor 1 | Yes |
Bank 2 - Sensor 2 | Yes |
Bank 2 - Sensor 3 | No |
Bank 2 - Sensor 4 | No |
Component | Description | Value | Minimum | Maximum | Units | Result |
Component Id $01 | TID $01 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $02 | TID $01 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $03 | TID $01 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $04 | TID $01 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $05 | TID $01 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $01 | TID $02 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $02 | TID $02 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $03 | TID $03 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $04 | TID $03 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $05 | TID $04 - Manufacturer Defined | 22 | 10 | N/A | Pass | |
Component Id $2F | TID $05 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $2D | TID $05 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $25 | TID $05 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $01 | TID $09 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $01 | TID $09 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $03 | TID $09 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $03 | TID $09 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $02 | TID $09 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $02 | TID $09 - Manufacturer Defined | 0 | 0 | N/A | Pass | |
Component Id $04 | TID $09 - Manufacturer Defined | 0 | N/A | 0 | Pass | |
Component Id $04 | TID $09 - Manufacturer Defined | 0 | 0 | N/A | Pass |
Vehicle Identification Number | Not Available |
Calibration ID - $10 | 1121530879050001 |
Calibration Verification Number | Not Available |
