Risk of death
caused by contact with parts conducting high voltages. |
Do not touch parts which conduct high voltages. Persons who wear electronic implants (e.g. heart pacemakers) must not perform any work on the ignition system. |
AS15.10-Z-0001-01A
Risk of fatal injury
when touching parts conducting high voltage when the ignition is switched off |
After ignition is turned OFF, only disconnect the plug on the ECI power pack after first waiting for 3 minutes. The voltage in the condenser dissipates in this time. |
AS15.15-Z-0001-01A
Notes on avoiding damage to ignition system |
Engine 137 |
AH15.10-P-0002-01L
All checks on the electrical system gasoline injection system ME engine 137 are described in STAR DIAGNOSIS. The following list contains the fault code description for the corresponding fault code |
Fault code STAR DIAGNOSIS
Readout on generic scan tool) |
Possible cause |
Note |
Fault code description |
| P2004 (P0100) |
Hot-film mass-air sensor ME - fault code description |
AD07.61-P-4000-01L |
| P2007 (P0105) |
Pressure sensor ME - fault code description |
AD07.61-P-4000-02L |
| P2006 (P0110) |
Intake air temperature sensor ME - fault code description |
AD07.61-P-4000-03L |
| P2005 (P0115) |
Coolant temperature sensor ME - fault code description |
AD07.61-P-4000-04L |
| P202D (P0125) |
AD07.61-P-4000-04LA |
| P200F (P0130) |
O2
sensor signal - fault code description ME |
Right O2
sensor upstream of TWC for cylinders 1 to 3 |
AD07.61-P-4000-06L |
| P2010 (P0136) |
O2
Right O2
sensor downstream of TWC for cylinders 1 to 3 |
| P2082 (P0130) |
O2
Right O2
sensor upstream of TWC for cylinders 4 to 6 |
| P2083 (P0136) |
O2
Right O2
sensor downstream of TWC for cylinders 4 to 6 |
| P20A9 (P0150) |
O2
Left O2
sensor upstream of TWC for cylinders 7 to 9 |
| P20Aa (P0150) |
O2
Left O2
sensor upstream of TWC for cylinders 10 to 12 |
| P20Ab (P0156) |
O2
Left O2
sensor downstream of TWC for cylinders 7 to 9 |
| P20AC (P0156) |
O2
Left O2
sensor downstream of TWC for cylinders 10 to 12, |
| P200E (-) |
O2
Right O2
downstream of TWC for cylinders 1 to 3, sensor condition change |
AD07.61-P-4000-06LA |
| P2081 (-) |
O2
Right O2
downstream of TWC for cylinders 4 to 6, sensor condition change |
| P20C6 (-) |
O2
Right O2
downstream of TWC for cylinders 7 to 9, sensor condition change |
| P20C7 (-) |
O2
Right O2
downstream of TWC for cylinders 10 to 12, sensor condition change |
| P207F (-) |
Aging of O2
sensor upstream of TWC - fault code description ME |
Right O2
sensor upstream of TWC for cylinders 4 to 6, correction parameter limit exceeded |
AD07.61-P-4000-07L |
| P20A5 (-) |
Aging of O2
Left O2
sensor upstream of TWC for cylinders 7 to 9, correction parameter limit exceeded |
| P20A6 (-) |
Aging of O2
Left O2
sensor upstream of TWC for cylinders 10 to 12, correction parameter limit exceeded |
| P200C (-) |
Aging of O2
Right O2
sensor upstream of TWC for cylinders 1 to 3, correction parameter limit exceeded |
| P2080 (P0133) |
Aging of O2
Right O2
sensor upstream of TWC for cylinders 4 to 6, cycle duration too long |
AD07.61-P-4000-07LA |
| P20A7 (P0153) |
Aging of O2
Left O2
sensor upstream of TWC for cylinders 7 to 9, Cycle duration too long |
| P20A8 (P0153) |
Aging of O2
Left O2
sensor upstream of TWC for cylinders 10 to 12, cycle duration too long |
| P200D (P0133) |
Aging of O2
Right O2
sensor upstream of TWC for cylinders 1 to 3, cycle duration too long |
| P2008 (P0135) |
O2
sensor heater - fault code description ME |
Right O2
sensor upstream of TWC for cylinders 1 to 3, internal resistance |
AD07.61-P-4000-08L |
| P2009 (P0141) |
O2
Right O2
downstream of TWC for cylinders 1 to 3, internal resistance |
| P2088 (P0135) |
O2
Right O2
sensor upstream of TWC for cylinders 4 to 6, internal resistance |
| P2089 (P0141) |
O2
Right O2
downstream of TWC for cylinders 4 to 6, internal resistance |
| P20B3 (P0155) |
O2
Left O2
sensor upstream of TWC for cylinders 7 to 9, internal resistance |
| P20B4 (P0155) |
O2
Left O2
sensor upstream of TWC for cylinders 10 to 12, internal resistance |
| P20B5 (P0161) |
O2
Left O2
sensor downstream of TWC for cylinders 7 to 9, internal resistance |
| P20B6 (P0161) |
O2
Left O2
2 sensor downstream of TWC for cylinders 10 to 12, internal resistance |
| P20BE (P0135) |
O2
Right O2
2 sensor upstream of TWC for cylinders 1 to 3, voltage supply |
AD07.61-P-4000-08LA |
| P20BF (P0135) |
O2
Right O2
2 sensor upstream of TWC for cylinders 4 to 6, voltage supply |
| P20C0 (P0155) |
O2
Left O2
sensor upstream of TWC for cylinders 7 to 9, voltage supply |
| P20C1 (P0155) |
O2
Left O2
sensor upstream of TWC for cylinders 10 to 12, voltage supply |
| P20C2 (P0141) |
O2
Right O2
downstream of TWC for cylinders 1 to 3, voltage supply |
| P20C3 (P0141) |
O2
Right O2
downstream of TWC for cylinders 4 to 6, voltage supply |
| P20C4 (P0161) |
O2
Left O2
sensor downstream of TWC for cylinders 7 to 9, voltage supply |
| P20C5 (P0161) |
O2
Left O2
sensor downstream of TWC for cylinders 10 to 12, voltage supply |
| P2018 (-) |
Self-adaptation of mixture formation at its limit - fault code description ME |
for cylinders 1 to 3, Between idle speed and part load |
AD07.61-P-4000-09LA |
| P2087 (-) |
for cylinders 4 to 6, Between idle speed and part load |
| P20B1 (-) |
for cylinders 7 to 9, Between idle speed and part load |
| P20B2 (-) |
for cylinders 10 to 12, Between idle speed and part load |
| P2017 (P0170) |
for cylinders 1 to 3, in idle |
AD07.61-P-4000-09LB |
| P2086 (P0170) |
for cylinders 4 to 6, in idle |
| P20AF (P0173) |
for cylinders 7 to 9, in idle |
| P20B0 (P0173) |
for cylinders 10 to 12, in idle |
| P2016 (P0170) |
for cylinders 1 to 3, In the case of part load |
AD07.61-P-4000-09LC |
| P2085 (P0170) |
for cylinders 4 to 6, In the case of part load |
| P20AD (P0173) |
for cylinders 7 to 9, In the case of part load |
| P20AE (P0173) |
for cylinders 10 to 12, In the case of part load |
| P201D (P0201) |
Fault code description for fuel injection valves, ME |
Cylinder 1 |
AD07.61-P-4000-10L |
| P2021 (P0202) |
Cylinder 2 |
| P201F (P0203) |
Cylinder 3 |
| P2022 (P0204) |
Cylinder 4 |
| P201E (P0205) |
Cylinder 5 |
| P2020 (P0206) |
Cylinder 6 |
| P208A (P0207) |
Cylinder 7 |
| P20Bb (P0208) |
Cylinder 8 |
| P20B9 (P0209) |
Cylinder 9 |
| P20BC (P0210) |
Cylinder 10 |
| P208B (P0211) |
Cylinder 11 |
| P20Ba (P0212) |
Cylinder 12 |
| P2043 (P0300) |
Fault code description - ME - misfires |
Sum, emission limit |
AD07.61-P-4000-11L |
| P2044 (P0301) |
Misfire at cylinder 1 |
| P2045 (P0305) |
Misfire at cylinder 5 |
| P2046 (P0303) |
Misfire at cylinder 3 |
| P2047 (P0306) |
Misfire at cylinder 6 |
| P2048 (P0302) |
Misfire at cylinder 2 |
| P2049 (P0304) |
Misfire at cylinder 4 |
| P204A (P0307) |
Misfire at cylinder 7 |
| P204B (P0311) |
Misfire at cylinder 11 |
| P204C (P0309) |
Misfire at cylinder 9 |
| P204D (P0312) |
Misfire at cylinder 12 |
| P204E (P0308) |
Misfire at cylinder 8 |
| P204F (P0310) |
Misfire at cylinder 10 |
| P2050 (P0300) |
Sum, damaging to TWC |
AD07.61-P-4000-11LA |
| P2051 (P0301) |
| P2052 (P0305) |
| P2053 (P0303) |
| P2054 (P0306) |
| P2055 (P0302) |
| P2056 (P0304) |
| P2057 (P0307) |
| P2058 (P0311) |
| P2059 (P0309) |
| P205A (P0312) |
| P205B (P0308) |
| P205C (P0310) |
| P2034 (P0335) |
Fault code description for crankshaft position sensor, ME |
AD07.61-P-4000-13L |
| P201A (P0341) |
Camshaft Hall sensor - fault code description ME |
Camshaft Hall sensor for right cylinder bank |
AD07.61-P-4000-14L |
| P20B8 (P0340) |
Camshaft Hall sensor for left cylinders bank |
| P2003 (P0410) |
Air injection: malfunction (function chain) Fault code description ME |
right cylinder bank, cylinders 1 to 6 |
AD07.61-P-4000-15L |
| P20C9 (P0410) |
left cylinder bank, cylinders 7 to 12 |
| P200B (P0422) |
Fault code description - three-way catalytic converter effectiveness too low |
Catalytic converter for cylinders 1 to 3 |
AD07.61-P-4000-16L |
| P207E (P0422) |
Catalytic converter for cylinders 4 to 6 |
| P20A3 (P0432) |
Catalytic converter for cylinders 7 to 9 |
| P20A4 (P0432) |
Catalytic converter for cylinders 10 to 12 |
| P2015 (P0440) |
Purge control system has leak (function chain) Fault code description ME |
Purge system leaking |
AD07.61-P-4000-17L |
| P2013 (P0455) |
Major leak in purge system |
| P2014 (P0422) |
Minor leak in purge system, a fine leak |
| P2075 (P0442) |
Minor leakage in purge system, micro leak |
| P2026 (P0443) |
Fault code description for purge control valve, ME |
AD07.61-P-4000-19L |
| P2025 (P0446) |
Activated charcoal canister shut-off valve ME - fault code description |
Voltage supply |
AD07.61-P-4000-20L |
| P2012 (P0446) |
Plausibility |
| P201C (P0450) |
Tank pressure sensor ME - fault code description |
Voltage supply |
AD07.61-P-4000-21L |
| P2072 (P0450) |
Plausibility |
AD07.61-P-4000-21LA |
| P202B (P0507) |
Idle speed control - fault code description ME |
AD07.61-P-4000-24L |
| P2069 (P0700) |
Engaged gear implausible or transmission leaky - fault code description ME |
AD07.61-P-4000-27L |
| P206A (P0700) |
Command valve jams in the pressure position - fault code description ME |
AD07.61-P-4000-28L |
| P205E (P0702) |
ETC control unit ME - fault code description |
Internal fault |
AD07.61-P-4000-29L |
| P2067 (P0705) |
Selector lever module wrongly coded |
| P2068 (P0720) |
CAN message re wheel speed at rear from ESP control unit missing or faulty |
| P20D5 (P0702) |
The torque request from the EGS control unit is implausible. |
| P20D6 (P0702) |
CAN transmission error of torque request from ETC [EGS] control unit |
| P20D7 (P0702) |
| P2065 (P0702) |
Supply voltage for valves - fault code description ME |
AD07.61-P-4000-30L |
| P2066 (P0715) |
Supply voltage and function of rpm sensors - fault code description ME |
AD07.61-P-4000-31L |
| P20Ca (P0500) |
CAN fault detection ME - fault code description |
Vehicle speed signal for left rear wheel from ESP control unit |
AD07.61-P-4000-32LA |
| P20Cb (P0500) |
Vehicle speed signal for left front wheel from ESP control unit |
AD07.61-P-4000-32LB |
| P2031 (P0600) |
CAN message from steering column module |
AD07.61-P-4000-32LC |
| P202F (P0600) |
CAN message from ABC control unit |
AD07.61-P-4000-32LD |
| P2037 (P0600) |
CAN message from ETC [EGS] control unit |
AD07.61-P-4000-32LE |
| P2030 (P0600) |
CAN message from electronic selector lever module control unit |
AD07.61-P-4000-32LF |
| P2036 (P0600) |
CAN message from ESP control unit |
AD07.61-P-4000-32LG |
| P20D1 (-) |
Torque request from DTR control unit implausible |
AD07.61-P-4000-32LH |
| P20D2 (-) |
CAN transmission error of torque request from DTR control unit |
| P20D3 (-) |
| P20D9 (-) |
Torque request from ESP control unit implausible |
AD07.61-P-4000-32LJ |
| P20Da (-) |
CAN transmission error of torque request from ESP control unit |
| P20Db (-) |
| P20E4 (-) |
Implausible signal from stop lamp switch |
AD07.61-P-4000-32LK |
| P20E5 (-) |
CAN transmission error of signal from stop lamp switch |
| P20E6 (-) |
| P203E (P0600) |
CAN message from instrument cluster |
AD07.61-P-4000-32LL |
| P206D (P0730) |
Gear position comparison negative (on multiple occasions) - fault code description ME |
AD07.61-P-4000-33L |
| P206B (P0740) |
Torque converter lockup clutch - fault code description ME |
AD07.61-P-4000-34L |
| P2062 (P0743) |
Pulse width modulation solenoid valve for torque converter lockup - fault code description ME |
AD07.61-P-4000-35L |
| P2063 (P0748) |
Modulating pressure control solenoid valve - fault code description ME |
AD07.61-P-4000-36L |
| P2064 (P0748) |
Shift pressure control solenoid valve - fault code description ME |
AD07.61-P-4000-37L |
| P205F (P0753) |
Solenoid valve 1-2/4-5 for shift mechanism - fault code description ME |
AD07.61-P-4000-38L |
| P2060 (P0758) |
Solenoid valve 2-3 for shift mechanism - fault code description ME |
AD07.61-P-4000-39L |
| P2061 (P0763) |
Solenoid valve 3-4 for shift mechanism - fault code description ME |
AD07.61-P-4000-40L |
| P2029 (P0340) |
Camshaft timing (function chain) Fault code description ME |
Right cylinder bank |
AD07.61-P-4000-43L |
| P202A (P0340) |
Left bank of cylinders |
| P20CF (P0120) |
Fault code description for pedal value sensor, ME |
Voltage difference between signal 1 and signal 2 |
AD07.61-P-4000-45L |
| P20DC (P0120) |
Open circuit on signal path 1 |
| P20DD (P0120) |
Short circuit on signal path 1 |
| P20DE (P0120) |
Open circuit on signal path 2 |
| P20DF (P0120) |
Short circuit on signal path 2 |
| P20E3 (P0120) |
Voltage supply for pedal value sensor |
| P2032 (P0120) |
Throttle valve actuator ME - fault code description |
Actual value potentiometer |
AD07.61-P-4000-49L |
| P2097 (-) |
Throttle valve jams, iced up |
AD07.61-P-4000-49LA |
| P202E (P0120) |
Adjustment |
AD07.61-P-4000-49LB |
| P209C (-) |
Cylinder shutoff valve does not close for cylinder shutoff OFF - fault code description ME |
Cylinder shutoff valve for cylinders 7 to 9 |
AD07.61-P-4000-52L |
| P209D (-) |
Cylinder shutoff valve for cylinders 10 to 12 |
| P20A2 (-) |
An inlet valve for cylinder is not operated at cylinder cutoff OFF-fault code description ME. |
AD07.61-P-4000-55L |
| P208E (-) |
Cylinder shutoff valve - fault code description ME |
Cylinders 10 to 12, coil 1 |
AD07.61-P-4000-56L |
| P208F (-) |
Cylinders 10 to 12, coil 2 |
| P2092 (-) |
Cylinders 7 to 9, coil 1 |
| P2093 (-) |
Cylinders 7 to 9, coil 2 |
| P209B (-) |
Exhaust flap switchover valve - fault code description ME |
AD07.61-P-4000-57L |
| P2091 (P0520) |
Cylinder shutoff oil pressure sensor - fault code description ME |
AD07.61-P-4000-58L |
| P201B (P0560) |
ME control unit voltage supply - fault code description |
AD07.61-P-4000-59L |
| P2039 (-) |
Oil sensor - fault code description, ME |
Oil level implausible |
AD07.61-P-4000-60L |
| P2040 (-) |
Oil quality implausible |
| P2041 (-) |
Water in engine oil |
| P2076 (-) |
Oil temperature implausible |
| P2099 (-) |
An exhaust valve for cylinder is not operated at cylinder cutoff OFF-fault code description ME. |
Cylinder 8 |
AD07.61-P-4000-61L |
| P209A (-) |
Cylinder 10 |
| P209E (-) |
Cylinder 7 |
| P209F (-) |
Cylinder 11 |
| P20A0 (-) |
Cylinder 9 |
| P20A1 (-) |
Cylinder 12 |
| P2098 (-) |
Crash signal implausible - fault code description, ME |
AD07.61-P-4000-62L |
| P207D (-) |
EIS control unit - fault code description, ME |
AD07.61-P-4000-63L |
| P203A (P0460) |
Fill level of fuel tank - fault code description ME |
AD07.61-P-4000-64L |
| P20CD (-) |
Air conditioning - fault code description ME |
AC compressor torque implausible |
AD07.61-P-4000-65L |
| P20CE (-) |
Refrigerant pressure in air conditioning too high |
| P20D0 (-) |
The air conditioning requests an implausible fan output. |
| P20D8 (-) |
ESP control unit - fault code description, ME |
ESP fault |
AD07.61-P-4000-66L |
| P206E (-) |
Transmission version implausible - fault code description ME |
Coded as having a manual transmission, vehicle has automatic gear selection |
AD07.61-P-4000-67L |
| P206F (-) |
Wrongly coded or fault in CAN communication with ETC [EGS] control unit |
| P2070 (-) |
Undervoltage on ETC [EGS] control unit |
| P20E7 (P0301) |
Ion current signal from a cylinder implausible fault code description ME |
Cylinder 1 |
AD07.61-P-4000-68L |
| P20E8 (P0302) |
Cylinder 2 |
| P20E9 (P0303) |
Cylinder 3 |
| P20Ea (P0304) |
Cylinder 4 |
| P20Eb (P0305) |
Cylinder 5 |
| P20EC (P0306) |
Cylinder 6 |
| P20F3 (P0307) |
Cylinder 7 |
| P20F4 (P0308) |
Cylinder 8 |
| P20F5 (P0309) |
Cylinder 9 |
| P20F6 (P0310) |
Cylinder 10 |
| P20F7 (P0311) |
Cylinder 11 |
| P20F8 (P0312) |
Cylinder 12 |
| P2023 (P0410) |
Air injection relay - fault code description ME |
AD07.61-P-4000-69L |
| P2019 (-) |
Antiboil protection for coolant - fault code description ME |
AD07.61-P-4000-70L |
| P2073 (-) |
Electrical suction-type fan - fault code description, ME |
AD07.61-P-4000-71L |
| P2090 (-) |
Connectors on O2
sensors wrong way round - fault code description ME |
AD07.61-P-4000-72L |
| P2033 (-) |
Cruise control pushbutton switch - fault code description ME |
AD07.61-P-4000-73L |
| P2042 (-) |
Safety fuel cut-off detected - fault code description ME |
AD07.61-P-4000-74L |
| P202C (P0115) |
Coolant thermostat - fault code description, ME |
AD07.61-P-4000-76L |
| P20BD (P0378) |
Angular deviation of camshaft relative to crankshaft - fault code description ME |
Camshaft for left cylinder bank to crankshaft |
AD07.61-P-4000-77L |
| P203D (P0370) |
Camshaft for right cylinder bank to crankshaft |
AD07.61-P-4000-77LA |
| P2024 (P0412) |
Air pump switchover valve - fault code description, ME |
AD07.61-P-4000-78L |
| P20C8 (P0415) |
| P2028 (P0340) |
Camshaft adjustment valve - fault code description ME |
AD07.61-P-4000-79L |
| P208C (P0340) |
| P20ED (-) |
Spark plug a or b of a cylinder - fault code description ME |
Cylinder 1 |
AD07.61-P-4000-80L |
| P20EE (-) |
Cylinder 2 |
| P20EF (-) |
Cylinder 3 |
| P20E0 (-) |
Cylinder 4 |
| P20F1 (-) |
Cylinder 5 |
| P20F2 (-) |
Cylinder 6 |
| P20F9 (-) |
Cylinder 7 |
| P20Fa (-) |
Cylinder 8 |
| P20Fb (-) |
Cylinder 9 |
| P20FC (-) |
Cylinder 10 |
| P20FD (-) |
Cylinder 11 |
| P20FE (-) |
Cylinder 12 |
| P20D4 (-) |
Load limitation active - fault code description ME |
AD07.61-P-4000-82AA |
| P203B (P0221) |
ME control unit - fault code description, ME |
Fault in function monitoring |
AD07.61-P-4000-91L |
| P203C (P0221) |
