COMAND RGB Video Specs
I have tried searching the net, this and other forums but have not has alot of luck finding the actual specs of the RGB input on the COMAND. Is it analog RGB or Digital, and the SYNC pin is that vertical sync or horz. Does anyone know where I can get the electrical specs of that port.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If you really wanted to know, you could hook some stuff up and figure it out. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
It's analog RGB, and sync could be ... well, if there's only one sync pin, it just might be composite sync. Or you could try sync on green as well. There are only a few combinations of one sync pin that will work with RGB.
And it is just a standard RGB video signal. Sync rates vary, I don't know the exact range that it will accept.
I very much doubt that this information will do you any good though.
Oh yeah, a Playstation 2 (or PSone) or any European-type device with a full-option SCART connector can be coaxed to give the proper output.
-s-
-s-
