How to add sub amp to 2000 S Class
My neighbor has a 2000 S Class with Nav and Bose. He likes the added bass I did in my wife's truck so he would like me to add a pair of 10s to the trunk. Who has done this on a 2000 model or similar? I would assume it can be done with a Pac SNI-35 or similar line output converter but where is the amplifier or where is the best place to do this?
Any help would be great. Thanks.
See the electronics location for the car at http://home.earthlink.net/~phdwebsit..._bulletins.htm - and no, that's not a mistake.
The connections between the HU and the amp are fiber optics. From the amp to the speakers, copper wire. Line output converter is the way to go. I can't help much on where to locate the new speakers, but you may have better sound if you also remove the rear sub from the parcel shelf behind the rear seat.
A search of the W220 and the Audio & Electronics forums using the terms "bass" or"subs" may give you some results of successful (or less than successful) speaker installations.
