V60 Bug! Any Fix?
V60 Bug! Any Fix?
Hello everybody,
I have a 2002 C230 with a Nav and V60c Car Kit. Here is a bug I discovered and wonder if there is a fix?
If you connect the phone it works like it should. However, if you power the phone off and power it back on while in the kit the phone book on the screen in front of me reads "System Busy." Here is the work around I use: I dial any phone number and once I connect I quickly hang up and then everything works again like it should.
Is there a flash update for the phone or the command system to fix this?
Thanks,
Jim
Thanks,
Jim
Super Moderator
I don't have that problem. Maybe the phones systems in the CL and C are different, however, I beleive technically they are the same in most aspects.
