Sponsored by: Innova
W124 E320 - Blower running...too high?
Old Oct 14, 2015 | 07:26 PM
I Am Jacks Merc's Avatar
2008 S550
I've got a 1995 E320 wagon, and can't seem to find anyone with the same problem on the MB World forums or otherwise:
My blower is intermittently running too high on my climate control. Sometimes on minimum fan setting it will be much higher than minimum, with other speeds only making it faster.
-When I hit the 'O' which should turn the whole system off, the blower keeps running regardless. It does not continue to run when the car is turned off.
-About 7000 km's ago the blower regulator was replaced with new, and the A/C system was refilled and given a clean bill of health.
-The A/C stopped working a while ago, I'm not sure why, but I don't see how that would effect the newer blower motor issue.
-Blower motor fuse has been checked, there are no cracks (it's been replaced with a regular fuse tie in).
-It appears to keep the right temperature.
I'm stumped, only thing I can think of are the control switches themselves, but don't want to rip stuff apart without knowing. Anyone had a similar issue?
