1999 W163 Bose Single DIN Help/Step by Step Guide?
Old 03-15-2016, 10:31 AM
nicolaselhani's Avatar
ML320 1999
I know this question has been asked before in many forms. But after more than ten days of research I decided that I need to ask it specifically for my case, at risk of being a redundant question and/or an annoyance.
Basically I have an ML320 1999 W163 with a Bose single DIN part no. 1638200286 (see pictures).
I am restoring the whole car leaving no detail unturned. And one of the things I want to do is upgrade the OEM radio to either AUX or Bluetooth.
There is a lot of useful information on this forum but essentially nothing precise enough for this specific model.
After much thought I realize the best way to do it is to solder the AUX cable to the radio. Though I am quite proficient in audio video and computer equipment, this older mechanical radio and soldering is something I’m completely new to.
To make a long story short, the following are the resources I found that have helped give me a general idea of what needs to be done:
1. Instructions with no pictures for the W203 https://mbworld.org/forums/audio-ele...-complete.html
2. Instruction with pictures for the W203 based on above post https://mbworld.org/forums/c-class-w...x-my-ipod.html
But I cannot extrapolate the information from either posts to apply to the W163 radio.
I found three other resources that do not involve soldering on this forum:
1. Buying this product, but is more specifically for USB/iPhone/iPod and it’s quite expensive, would just prefer an AUX http://www.autotoys.com/x/product.php?productid=14473
2. Buying this cheaper one, but apparently doesn’t work with the W163 single DIN Bose radio
Amazon.com: MINI ISO 4 CHANNEL LOW OUT BLAUPUNKT RADIO ADAPTER CABLE: Computers & Accessories Amazon.com: MINI ISO 4 CHANNEL LOW OUT BLAUPUNKT RADIO ADAPTER CABLE: Computers & Accessories
3. Buying this bluetooth module but the post is for the ML55 with the double DIN connect radio https://mbworld.org/forums/ml55-amg-...tion-pics.html
I attached photos of the radio.
So basically what I’m asking for is if someone can guide me through the process or point me to a resource that can help me solder an AUX cable to this specific Bose radio.
What steps I should take, what PINs to solder to on which board. How to disable the tape motors, etc.
Even if there is a more updated completely different way of doing, I’m open to suggestions.
Any help would be much appreciated.
Thanks,
Nick
Old 03-16-2016, 08:17 PM
jbondox's Avatar
beater with a heater
so you want to keep your 17 year old radio and band-aid it up for aux? have you ever heard of GIGO? garbage in garbage out... well the quality of that radio is low to begin with, I suggest just replacing it with an aftermarket and any 12v car audio shop can do this for a reasonable price
Old 03-14-2022, 11:53 AM
jekson's Avatar
c202k w203 2001
мой друг,приветствую тебя. я восстанавливаю такую же систему бозе. каких результатов ты добился?
my friend, greetings to you. I am restoring the same bose system. what results have you achieved?
Quick Reply: 1999 W163 Bose Single DIN Help/Step by Step Guide?
