Burmester Static Noise Issue
Hi guys, so I've been having a noise issue with my Burmester speakers. It sounds like a static noise and usually happens when you first start the car or in cold weather (seems strange but that's what I've realised). They also seem to be happening from the rear speakers as far as I can tell. Does anyone know what the cause of this problem may be and if any solutions are available? Make sure you check out the links below so you can hear it for yourself. Thanks everyone!
https://vimeo.com/169864484
https://vimeo.com/169864482
I think it might be time for some new speakers, disconnect both and hook up a test speaker from home. you can also have a bad amp also, but by disconnecting them and turning the effects off on the COMAND you will know either it is the speakers or amp
Tharu Perera (06-08-2016)
