changing from USA to European mode NTG 2.5 on my ML 350 2010
ML 350 Bluetec 2010
Hi, I bought an USA version of ML 350 w164 2010, and use it in europe. I need to change the radio mode into european, in order to navigate through european bandwiths as well as getting the RDS info ito it. I entered the engineering mode in the NTG 2.5 but I can't find a tool to do it from there, can someone give me a solution?
Thanks!
Navigation map is easy thing, problem with radio frequencies. EU NTG2.5 uses 0.5 step for radio stations, USA NTG2.5 has no tuner board soldered inside head unit, instead it gets all freq from SAT tuner. You need to use radio board from EU, or add tuner. Without tuner radio will work but signal level will be very weak...
