722.6 controller
722.6 controller
Hi, I just wanted to let you know that we started doing opensource 722.6 controller project for arduino in Finland, feel free to share and take part of
https://github.com/mkovero/7226ctrl
carles (07-14-2019)
W210 3.0TD '97 & W163 270CDI '04
Work in progress
At now we test hardware.
Prop pinout test
LCD and shifter test
Prop pinout test
New revision - now compatible with original EGS51/52 pinout and enclosure. 4-layer PCB
Features:
- Teensy 3.5 MCU
- 722.6 full support (all selenoids, 2x speed sensors, temperature sensor)
- RPM ans Speedometer out
- CAN-Bus onboard
- LCD support (parameters from transmission, speed, temperature etc.)
- double professional 5V linear regulators (internal and external power)
- reverse battery protection
- ABS RPM and crankshaft sspeed sensor input
- TPS input
- W202/W210 gear stick support (more soon)
- manual (with paddles) and automatic gear shifting
Features:
- Teensy 3.5 MCU
- CAN-Bus onboard
- TPS input
