MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   Audio & Electronics (https://mbworld.org/forums/audio-electronics-38/)
-   -   Electronic problem - steering column and driver's seat (https://mbworld.org/forums/audio-electronics/700455-electronic-problem-steering-column-drivers-seat.html)
ChefDJ Mar 4, 2018 07:59 AM
Hi all, I'm new here.
I live in South Africa and have a 2002 W203 C270 CDI Elegance. It has around 230k km on the clock.
There are a few niggles I need to sort out, but most important is the following:
I took the car for a wash today and when I collected the car the steering column and driver's seat would not move (convenience). I tried the controls and neither the seat nor the steering wheel will adjust at all, in any direction. I checked all the fuses in the trunk compartment as well as the little compartment in the dash and they seem fine.
Using the seat memory switch only adjusts the mirrors. The passenger seat is working fine.
Driving with the seat all the way back and the steering wheel all the way up is not what I call fun. If anyone has any advice, I would be most appreciative.
Thanks in advance!
NomadTitan Jun 2, 2020 08:14 PM
New and thank you
Just got my first merc. C class sedan 4Matic w204. Had the same issue as described. Unplugged the control box and plugged it back it. Worked like a charm. Ty all
© 2026 MH Sub I, LLC dba Internet Brands
