Wiper Fluid Pump on 2006 c230
Hello!
My wiper fluid pump seems to not be getting power to it (hasn't worked since I purchased the vehicle). I have tested the pump off of the vehicle and it works. I used a tester to see if the wire/plug was getting power to the pump and it seems like it is not.
There is not a fuse for the fluid pump. It just says "electronic". From what I can tell the wire goes up and into the fuse box and plugs in. But there is not a fuse.
Any ideas? I am thinking that maybe the actual switch (located on the end of the turn signal) may be bad? Are those hard to replace?
Welcome to any suggestions. Thanks!
