Car Doesn’t Always Crank. Hoping to Diagnose Issue
Old 07-29-2018, 09:48 AM
Punisher007's Avatar
2010 E550 Coupe
Hi everyone!
I’m having an issue which I can’t seem to find information on but am hoping someone can chime in and provide some direction in hopes of addressing my problem.
Every so often I when I open the driver side door I notice a few of the icons on the instrument cluster come on for a second and go off. When this happens and I insert the key into the ignition the car will not crank. I have to (for a few minutes) take the key in and out of the ignition, wait a few seconds, and continuously turn the key in hopes of cranking the engine over. After a few minutes of trying this the hazard lights will double blink and the car starts right up with no issues.
I’ve connected the car to my MB Muliplexer, ran diagnostics on Xentry, but don’t ever get a fault code. Does anyone know what the potential problem is and a solution? Thank you in advance for your assistance.
Old 07-29-2018, 10:11 AM
ItalianJoe1's Avatar
2003 CL 600
ESL failing? Do you hear it release when you first put the key in?
Old 07-29-2018, 11:48 AM
2010 E550 Coupe
Hey Joe,
it does release however is ver is there a way of testing it? I’m not so familiar with the functions of the ESL
Old 07-29-2018, 11:55 AM
2003 CL 600
If it release and still won't start, you need to look at why. Check EZS actual values when turning the key, is it recognizing the key being turned? If there are no faults, it points to a bad ignition switch (EZS) most likely.
The ESL just releases the column when the key is inserted. But if it isn't doing that, nothing else works as the car won't turn the ignition on until the ESL opens up.
Old 07-29-2018, 12:21 PM
2010 E550 Coupe
When I initially open the car door I see the few lights on the cluster automatically go on which automatically lets me know that I will have the ignition issue. Would you say this is also the a symptom of a bad ignition switch?
Old 07-29-2018, 04:09 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
'03 CL600 - stock ... 12.5 @ 115
hhhhmmmmmm.
My 1967 Mustang GTX did about the same!
From days gone by.
Cheers
Old 07-29-2018, 05:04 PM
2003 CL 600
Hard to say, would require more diag. You're in south FL, where at? I'm a tech at MB of Miami
2003 CL 600
hhhhmmmmmm.
From days gone by.
Cheers
I think the CL does it in slightly more luxury than the mustang did though
Old 07-29-2018, 05:44 PM
2010 E550 Coupe
I’m in the Boca Raton area.. Wiuld it be far fetched to think it may have something to do with the factory security system?
Old 07-30-2018, 11:11 PM
2003 CL 600
There still shouldn't be random lights coming on the dash when opening the door. I'd wager there's something disrupting the CAN and causing it to not allow the car to start, but actual diag would be necessary, anything else would just be me guessing at it, which is no help. It's definitely not a common problem.
Old 07-31-2018, 11:02 PM
2010 E550 Coupe
is there a specific diag I should do because when I run Xentry I don’t get any error codes?
Old 08-01-2018, 01:46 PM
2003 CL 600
Gotta look at actual values in the DAS system and EZS when it's happening, see if the signals are getting through. This is a tough one to diagnose without having the car in front of me.
Old 08-02-2018, 09:23 PM
2010 E550 Coupe
Thank you Joe for all of your help! I’ll see if I come across anything that doesn’t seem kosher and let you know! Hope you have a goodnight
Quick Reply: Car Doesn’t Always Crank. Hoping to Diagnose Issue
