Is the MCS unit from ML Double DIN or 2.5?
2012 W204 C300 4Matic Sport (Facelift)
Just a quick question...
That is will it fit in the double din dash panel used by the regular command 2.0 such as those in the E320?
Thanks,
Hish
Thanks,
Hish
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Is the MCS unit from ML Double DIN or 2.5?
Thanks,
Hish
Thanks,
Hish
Mounting pins are a bit different, you will need to either remove the pins off the MCS or cut slots in the plastic on the E320 (or wherever it goes).
-s-
