Sponsored by: Innova
quiet AUX port (just installed) ???
Old Aug 10, 2004 | 03:19 AM
Dema's Avatar
i535
Originally Posted by inFiniTE LooP
the mp3 player is a Creative Labs Nomad II, i dont see what difference it makes though since i'm turning the volume all the way up and when i do that while connected to headphones it makes my ears wanna bleed, the output from the mp3 player should be fine, it seems to be the AUX port since all other audio sources are much louder when turned up that high, i was just wondering if anyone else shared this experience so that i would know if that's really how it is suppose to be or if something is wrong
As I understood you use phone out of Nomad. It can be impedance matching problem. I have some old Nomad, so I can do a test and will tell you result, so you will know certainly where a problem is.
Old Aug 10, 2004 | 03:51 AM
miroj's Avatar
Originally this is what I expected to be the point of conversation. I am interested to hear what you find out in terms of absolute values.
Old Aug 11, 2004 | 01:49 AM
Dema's Avatar
i535
I tried Nomad II and it's very loud, so I can adjust volume to make it on the same level as I get it from CD. Anyway, it doesn't prove that you have incorrect installation. Do you have any friend with command, so you can compare?
Old Aug 11, 2004 | 02:32 AM
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
i know somebody with a U.S. spec comand, that will be over tomorrow, i'll see if i can try hers out and let you know the results...thanks~!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
