Can I upgrade my 03 CL CD based Comand unit to DVD?
And interestingly the guy said that is plug and play no modification needed.
Is it true? Can somebody shed a light on this?
thanks!
No, honestly, a new DVD based comand unit, which is for S and CL vehicles from 2005 and up, won't be 'just plug and play' for the older models. Not a chance!
Greetingz,
BigSis
NO RETURN ..
You basally would have to rewire your entire bus in the entire vehicle from what it sounds like.
Would cost a ton in time and material not to mention we still don't know if the end result would work.
Not worth it in my opinion.
greetingz,
So, would the 05 command work with the 04 wiring? (specifically an SL55) I would think the 03 and 04 are the same wiring since they use the same command unit but I could be wrong.
Greetingz,
BigSis
Greetingz,
BigSis
