NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!
Old 03-16-2013, 02:15 PM
pparker1213's Avatar
2012 C250
Just installed mine and I don't think there is any way to install without "loosening" (it does not need to be removed) the inner fender cover. Turn the tire as far one way as you can to get some room first. I pulled the first 3 retaining clips there and then there is one more on the bottom that I pulled. Then I just pulled the cover out far enough to see in there and get my hand in.
Remove the bulb - half turn right or left I forget.
Then you just push a tab that is pretty easily accessible and the outer part (that you ordered) separates from the inner part. The inner part stays inside the fender loose and then you clip the newer outer section to it from the outside.
Reinstall the bulb and you should be set.
The first one took me 10 minutes to figure out and the second took me about 3 minutes.
Good luck
Old 03-16-2013, 08:42 PM
DameMD's Avatar
X3 M40i
I installed mine too, about 10 mins total to do both sides.
We should have a guinea pig start a thread with pictures of our cars with the clear corners. It would be nice to see different colors of the C Coupe with the different shades of the clear corners. i.e clear with smoke edges vs smoked
Old 03-18-2013, 03:33 PM
NauticaX's Avatar
2013 C350 Coupe
Just purchased! Can't wait to get them.
Old 03-20-2013, 05:15 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Just installed them today. I got the lightly smoked ones
Old 03-21-2013, 11:19 AM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Originally Posted by capt_paul
Just installed them today. I got the lightly smoked ones.
Your pics don't work!!!
Old 03-21-2013, 03:57 PM
capt_paul's Avatar
Fixed!!
Old 03-21-2013, 08:18 PM
  #32
NauticaX's Avatar
2013 C350 Coupe
Good luck
I can't seem to get it to clip back on. The 2 prongs on the non clipping side I can't get back on. What's the secret??
Old 03-21-2013, 08:59 PM
  #33
capt_paul's Avatar
I held up the black piece from the back side, then put the front hooks from the light into the holder from the outside. I then held the piece into position in the fender, then pushed the back of the lens to set the rear tab into black piece.
The first one took me about 15 minutes to figure it out, then only 10 minutes to do the other one. Be carefull not to break the rear tab or you will be SOL
Old 03-21-2013, 11:04 PM
  #34
NauticaX's Avatar
2013 C350 Coupe
Oh damn why didn't I think of that! I had the back piece in the back while trying to put the front piece in front. SUPER frustrating.. took over an hour for both sides ... I suck So happy I got it in though. Almost gave up and was gonna take it to dealer.
Old 03-22-2013, 08:12 AM
  #35
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ they look great on a black car!
Old 03-24-2013, 12:03 PM
  #36
2012 C250
pics clear on palladium silver
Just a couple pics for comparison
Attached Thumbnails NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!-pic.jpg   NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!-pic2.jpg   NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!-pic3.jpg
Old 04-03-2013, 09:55 AM
  #37
gdot's Avatar
c350 coupe
i've been waiting for these! will order once I get home!
Old 04-03-2013, 04:49 PM
  #38
sh0ko's Avatar
C350 4Matic Coupe
heres another smoke corner on black
recently splurged on some vossens which are on there way but havent heard anything yet...so worried... lol
once those are paid off ill be buying the black grille!
thanks for the part # captpaul
Attached Thumbnails NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!-20130401_151930.jpg
Last edited by sh0ko; 04-03-2013 at 04:50 PM. Reason: addition of type of clear corner
Quick Reply: NOW AVAILABLE - Clear/Smoked Side Marker for Coupes!!
