AutoTalent | Renntech Ecu + Exhaust + Suspension for Mercedes-benz C43 Amg 2015-2019
Old Oct 15, 2019 | 06:03 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu 1!
Click HERE to order Performance Ecu 2!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s! Our experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RennTech performance software unleashes the true potential of your Mercedes. With the RennTech ECU Plus Upgrade the W205 - C 43 AMG Sedan gains up to +41 HP and +62 LB-FT, based on power numbers measured by RENNtech. Please note that the Mercedes M276 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RennTech ECU Plus Upgrade for the W205 - C 43 AMG Sedan is 416 HP and 460 LB-FT.
Features
Gains up to +41 HP and +62 LB-FT
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance
362 HP @ 5,500-6,000 RPM; 384 LB-FT @ 2,000-4,200 RPM
375 HP @ 5,600 RPM; 398 LB-FT @ 3,300-3,600 RPM
Modified Performance
416 HP @ 5,450 RPM; 460 LB-FT @ 3,250-3,600 RPM
Renntech Performance Coil Over Suspension
Click HERE to order Coil Over Suspension!
RennTech C-Class adjustable suspension kit offers not only overall improved aesthetics and an aggressive vehicle stance but improves both vehicle handling and performance. Our proprietary suspension kit lowers your vehicle up to 1.75" via adjustable spring perches on your OEM dampers. Constructed of high strength, lightweight aluminum our suspension kit allows four-corner independent ride height adjustments and the ability to perform vehicle corner weighting. RennTech complete suspension conversion allows full adjustment without the need to purchase an entire Coilover conversion kit and comes with an adjustment tool to make on-the-fly suspension adjustments.
Features
RennTech sport lowering springs for front and rear
RennTech height adjustable spring perches for front and rear
RennTech adjustment wrench for spring perches
Lowering Range: up to 1.25" in the front and up to 1.75" in the rear
Four corner height adjustability
OEM electronic damper control is retained
Aggressive, lowered vehicle stance
Improved vehicle handling and performance
Renntech Performance Exhaust Valve Module
Click HERE to order Exhaust Valve Module 1!
Click HERE to order Exhaust Valve Module 2!
RennTech plug & play EVM Exhaust Valve Module allows you to open the exhaust flaps of your car 100% at all times by pressing Button 1 on the remote control. If you wish to go back to factory settings simnply press Button 2. This gives you complete control over the exhaust sound and rumble of your car at any time regardless of speed, RPM or driving mode. The RennTech Exhaust Valve Module is made in Germany. If your car is equipped with factory exhaust flaps, with or without a center console button to open or close them, factory settings do not allow the flaps to fully open unless certain speed and/or RPM have been reached. For example, while cruising the exhaust flaps will never fully open.
Features
Activation completely independent regardless of drive mode
Override your cars factory exhaust flap setting with the push of a button.
No cutting wires, no damage to factory cables, fully reversible
Software updates do not interfere with the functionality of the EVM exhaust flap module.
EVM does not engage with CAN-Bus
No interference with any control units.
Plug and Play with original plugs
1 x Exhaust Valve Module
2 x Remote Controls (Button 1 fully open, Button 2 back to factory)
Wiring harness (model specific)
Installation manual
Renntech Carbon Fiber Decklid Spoiler
Click HERE to order Decklid Spoiler Gloss Finish!
RennTech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz C-Class Sedan. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined C-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods, in order to create a smooth and high Matte finish. RennTech decklid spoiler was designed, engineered and tested in-house as a fully functional aerodynamic exterior upgrade. The decklid spoiler offers a smooth transition of airflow. Its high quality prepreg carbon fiber construction is finished in a beautiful gloss top coat to ensure years of durability and stunning good looks.This decklid spoiler is a fully functional aerodynamic component as well as an aggressive exterior enhancement. The design is perfect as a stand alone components.
Features
Stunning good looks of vehicles
High quality meterials used
Looking more aggressive
Carbon Fiber meterials
Design is perfect
Simple to install
Matte Finish
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
