whats the biggest tire size possible for a lowered 1999 c230k with 18's
i lowered my car with h&r springs and i'm currently using the thinnest smallest spring pad. i want to have a staggered setup. and also, i have carlsson 18x8.5 evo 1/6 diamond edition rims...will 255's fit on these? thanks
H&R kit is definitely lower than regular H&R sport spring...
255/35 should fit without rubbing with the correct offset off-course
Here is my car with
18x8 et 31mm 225/40/18 m and 18x9 et35mm 255/35/18(continental).
I have H&R sport spring with AMG-bilstein shock with thinnest spring pad front and rear. (I cut the front spring half coil, to match the height with the rear one)
Hope this helps
Regardz,
J Irwan
Here is my car with
Hope this helps
Regardz,
J Irwan
